? for those who installed aftermarket H/U-wiring designation
Old Mar 30, 2006 | 06:01 PM
Sid_xBicious's Avatar
Default ? for those who installed aftermarket H/U-wiring designation
I am planning on putting my OEM H/U to another car. there are 2 harness comming from the car to the H/U.
Beige harness
5 wires
red-
black-
yellow-white-?
white w/green stripe-?
Blue harness
9 wires
light green?
blue?
pink?
purple?
white with black stripe?
black withred stripe?
gray?
blue with yellow stripe?
dark green?
can someone please direct me on the designations of this wires. I'm assuming the beige harness is for power, and the blue harness is for speaker connection, but I appreciate it if someone can give me more info so I can make the hook up right.
thank you very much
sid
Old Mar 30, 2006 | 06:06 PM
hnefrdo's Avatar
I've never thought about putting a stock receiver into another car before. I didn't think it was possible for some reason.
Old Mar 30, 2006 | 06:17 PM
dgHotLava's Avatar
google is your friend....
http://www.installdr.com/Harnesses/Toyota-Wiring.pdf
enjoy.
Old Mar 30, 2006 | 07:08 PM
Originally Posted by dgHotLava
WOW!!!!!!
thank you very much!!!!!
man, my assumption is wrong. thanks for all the help!!!!
I have to edit the first post so no one makes the mistake.
thanks again!!!!
Old Mar 30, 2006 | 07:37 PM
dgHotLava's Avatar
no prob...
i'd hate to see you hook it up and have it blow up...
you can always order a plug set from you local stereo shop...that will have wires with the labels on them.
that way you do not need to cut your harness or the other cars harness...
Old Mar 30, 2006 | 08:06 PM
mfenske's Avatar
I'm with Hotlava on this, I suggest that for the sake of ease you should buy a reverse Scion harness (the one that plugs in to the radio) and a regular forward harness for the vehicle you are installing in to. Granted, you will spend more on parts but there will be no permanent modification to either the car or radio. Solder or crimp cap the wires and it's plug and play. Mark
Old Mar 30, 2006 | 08:23 PM
the H/U will go to my friends old truck, still have to find out if theres an existing lines. if not we'll have to put new wirings. lucky thing is I found a harness that is from a toyota, the guy that handed it to me did not specify what car but its exactly same as the xB harness.
So yes, instead of buying 2 harness, we'll just be crimping this to the new wires.
sid
NonStopTuning
Jun 29, 2015 07:42 PM
Frustratez
Feb 26, 2015 04:03 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
