Upgraded alternator/battery
Old Nov 26, 2005 | 03:25 AM
squirrel's Avatar
Default Upgraded alternator/battery
I did the "search" and couldn't find exactly what I wanted to know.
So the questions I have are:
Has anyone upgraded the alternator on their xB yet? If so, which model did you get, where, and what was the general pricing?
Does anyone know where to find an upgraded alternator for the xB?
I am running 1,600+ watts in my stereo system and am running video also.
Also, for those who have replaced their batteries, what did you replace it with?
ANY info would be greatly appreciated.
THANKS!
Old Nov 26, 2005 | 04:44 AM
05_camo_boxb's Avatar
i know optimas are nice battries...il look in my sound security mag and see if i can find you an alternater....if i do i ll pm you...not sure if they ofer one yet...
Old Nov 26, 2005 | 04:47 AM
Scion05BOPxB's Avatar
Ohio Generator makes altenator upgrades for most everything in the world.
Old Nov 26, 2005 | 05:01 AM
Flecs's Avatar
im interested in an alternator aswell... could you pm me if you find anything... and il lcheck into the ohio place
Old Nov 26, 2005 | 05:04 AM
sexyscionlover's Avatar
Optima yellow top would be an awesome improvement. I would do that first, then if that doenst help you, go to an Ohio generator (ive heard really good things)
Old Nov 26, 2005 | 05:17 AM
Flecs's Avatar
just out of curiosity... can you paint the tops of batteries... bc unless my box was solar yellow i wouldent want a big yellow battery in my white box
Old Nov 26, 2005 | 03:29 PM
ScionDad's Avatar
Well, that yellow top is instantly recognized as top shelf equipment. Even tho it doesn't match the blue and silver under here....it still looks good IMO. I bet it would look perfect under your hood.
Old Nov 26, 2005 | 03:32 PM
TXboxdriver's Avatar
https://www.scionlife.com/forums/vie...ght=alternator
Old Nov 27, 2005 | 06:32 AM
Flecs's Avatar
i see whatcha mean... ok thanks!
Old Nov 30, 2005 | 12:53 AM
squirrel's Avatar
Well, I did some researching.
The OEM alternator has an 80 amp output. The max draw on both of my amps is 202 amps. I don't turn my stereo up anymore than halfway, so even then, the draw is prolly around 100 amps.
So, I'm going w/ the yellow top OPTIMA, and 2 farad cap on the 1k watt amp.
Either way, I'm still overloading the alternator and making it work harder than it should.
Another option is a second battery, but again the weak link is the alternator.
So, I'm hoping to find a rewind, hopefully 120 amp output, for the OEM case that will bolt right in. I don't want to mess w/ rewiring the car and fabbing new alternator brackets, and having to worry about pulley sizes.
Not bad for a poser, eh?
Old Nov 30, 2005 | 03:13 AM
windowtint's Avatar
any alternator shop can wind more wire into the alternator (as you mention), it's a 'gimmee' task for any good shop - basic stuff. And cheaper that a replacement - AND you know it will fit right --- since it is the original casing 'n all....
Old Nov 30, 2005 | 03:47 AM
-Keith-'s Avatar
Brad optima battery stinger alternator... Ill look for some links
Old Nov 30, 2005 | 03:50 AM
-Keith-'s Avatar
Here you go... http://stingerelectronics.com/web/prods/alternators.asp
Old Nov 30, 2005 | 06:12 AM
Piston's Avatar
Stinger does make an alternator for the xb, it would be nice, I am about to have mine rewound. The shop said they should be able to get me around 170. The would be nice, would help out with my sub amp that draws at full power almost 150 amps.
Brad If I I get high numbers like that would you be interested in having yours done as well?
Jason
Old Nov 30, 2005 | 11:19 AM
GLN305's Avatar
I just e-mailed Ohio Generator and they responded that they do make a 170-amp alternator for our xB's. It is a direct fit model, no mods required!
Old Nov 30, 2005 | 05:16 PM
squirrel's Avatar
I found a nice aftermarket universal that has 130 amp output. I just hgave to figure out what brackets and pulley are needed.
Thanks Keith!
Jason, Oh, that sounds promising! Thanks!
GLN305, did they say how much? Thanks!
Old Nov 30, 2005 | 06:04 PM
kkawana's Avatar
i agree on the yellow top....
tho may have to look into the alternator soon too.... specially if i plan on addin more screens....
got 2 JL amps.. 1000/1 and 300/4 .... battery was upgraded to a yellow top when system put in... hmm...
Old Nov 30, 2005 | 06:12 PM
squirrel's Avatar
Yeah, I have 3-7 inch screens, 1-4 inch screen one 15 inch drop down, a 400 watt power convertor, dvd player, HU, 600 watt amp and 1k watt amp. So I definitely need a higher output alternator. More to be added next year.
Old Nov 30, 2005 | 06:48 PM
engifineer's Avatar
Keep in mind, the second battery and cap do nothing to save your alternator. It must provide everything drawn by the entire electrical system. Your car is already using a good portion of that 80amps as well (especially at night), so you are grossly overloading it if you draw 100 from your sound system alone.
Old Nov 30, 2005 | 06:54 PM
squirrel's Avatar
The max draw on both of my amps is 202 amps. So even at low levels my draw is around half of that at 101 amps.
Thus the need to find to find at least a 120 amp alternator.
