volts 4 cam.
I just got this camera for my car, but I notice that the volts for the camera are 9volts. The car is 12volts, how can I drop the volts down so that I don’t burn the camera?
Oh yeah I didn’t want to install the cigarette lighter…………
here i found this online maybe you can buy this or something similar
http://www.powerstream.com/dc6.htm
Just a suggestion....
This is how i hooked up my camera via a switch to the 12V line
I used Ohm's law with a voltage divider to figure out the way to drop the Voltage
I have a 4V Cam that uses 80mA current
I know the input Voltage = 12V
I want an output = 4V
My Cam is an effective load (resistor) of 50 Ohms
By putting another resistor inline before the Cam i can cut the Voltage down
using voltage divider equation
I just soldered the 100 Ohm resistor inline, wrapped it with electrical tape and connected it to the 12V line. Cake :-p
If this were digital micro electronics, or an amp where the difference was 45A or 150A i would be more concerned. But in analogue electronics, all devices are set up for a lil' over voltage capacity. To be safe 190-200 Ohm resistor could prevent any over-voltage, but i havent had any trouble with my Cam so far
XB06
15
Oct 1, 2022 10:24 PM
gedster314
14
Nov 17, 2018 02:56 PM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
ScionDad
Mar 7, 2005 06:59 PM
