What size resistor??
Hello All.. wantded to know the size of resistor needed for a/c heater led's i have the leds but cant find the post on the size. read a post that said to use 470 ohm but not sure of the watts? thanks XbStorm.....
You can also google it like I did. If you know the specification of the LED then it will give you the required resistor.
This is the one that I used.
http://ourworld.compuserve.com/homep...Bowden/led.htm
It is helpful when you need to wire more than one LED in series (end to end)
Re: What size resistor??
Here is how you calculate it:
I'm assuming that you have a single White (or Blue) LED in series with each resistor.
Supply voltage=13V (roughly - when car is running).
Voltage across the LED=3.2V (assuming a White or blue LED).
Voltage across the resistor: 13-3.2=9.8V
Current flowing through the resistor: 9.8/470=0.021A
Wattage dissipated by resistor: 9.8 x 0.021 = 0.21W
So, a 470 ohm, 1/4 Watt (or larger) resistor will work.
This is an example of where we actually utilize all that basic math we learned in school... :D
Originally Posted by kkawana
haha peteski...gotta love it when that phrase "when am i gonna use that in real life?" comes back and bites us huh??
Who would've thunk... :D
rain7905643
03-14-2015 12:48 AM
ColonelSanders85
03-03-2015 03:31 AM
