XA Alarm Problem
Old Jul 29, 2007 | 01:38 AM
tonytc05's Avatar
Default XA Alarm Problem
I just installed the OEM alarm for my friend's 07' xA and ran into alittle problem. Everytime I press the lock button on the remote, the doors will not lock. The doors will unlock with the remote if I press the lock button in the car. It came with 2 new remotes and same problem on both of them. If any one had ran into this same problem please help me out. Thanks alot.
Old Jul 29, 2007 | 10:20 AM
SanchezHacker's Avatar
I don't have the OEM security system, but since it is made for scions then it should just work once installed. Check to make sure it was installed correctly, you can find the install manual here: http://www.trdsparks.com/install/08586-52973inst.pdf (TRDsparks.com). If it is installed fine and you still have that problem, then you might have a bad unit. Hope this helps.
Also, there are no 07 xAs. They stopped making them in December of 06 and they're just selling them till they run out.
idriveanxa
Mar 8, 2015 12:03 PM
IrjI619
Jan 28, 2015 05:21 AM
xdejablu3x
Regional - Mid South
Dec 29, 2014 02:15 AM
BV19869
Dec 11, 2014 06:05 PM
scionspecialistvegas
Dec 15, 2003 11:21 AM
