Xa RS3200 install
Hopefully this helps you out a bit:
DIRECTWIRE™ WIRING INFORMATION - SCION / XA / 2006 / Remote Start
12volts wht/blue (50A), wht/red (15A) + ignition harness
Starter black + ignition harness
Second Starter N/A
Ignition black/red + ignition harness
Second Ignition black/yellow + ignition harness
Third Ignition N/A
Accessory white/blue + ignition harness
Second Accessory N/A
Keysense yellow - ignition harness
Power Lock brown/yellow - driver kick, 18 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock blue/yellow to yellow/black - driver kick, 18 pin plug
Notes: Meter this wire while turning the key in the driver door key cylinder. Unlock requires a double pulse.
Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is green/black (-) in the passenger kick in a 14 pin plug.
Lock Motor blue/white 5wi driver kick, 13 pin plug
Unlock Motor blue/black to yellow/green 5wi driver kick, 13 pin plug
Parking Lights+ green + headlight switch
Notes: Also found at the top of the fuse box in a 13 pin plug.
Parking Lights- N/A
Hazards green/orange - hazard switch
Turn Signal(L) green/black + top of fuse box, 13 pin plug
Turn Signal(R) green/yellow + top of fuse box, 13 pin plug
Reverse Light red/black + top of fuse box, 9 pin plug
Door Trigger red/blue - top of fuse box, 9 pin plug
Dome Supervision use door trigger wire
Trunk/Hatch Pin common with door trigger wire
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm N/A
Factory Alarm Disarm N/A
Disarm No Unlock N/A
Tachometer black ac data link conn below fuse box, pin 9
Wait to start N/A
Brake Wire green/white + brake pedal switch
Parking Brake yellow/red - top of fuse box, gray 11 pin plug
Horn Trigger white/red - horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Second Starter N/A
Third Ignition N/A
Parking Lights- N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
No Type:
N/A
Part #: N/A
Update on the install. RS3200, 08586-52973inst.pdf
page 6
3. d removal of the single pin was a PITA to remove. This gave me the most trouble/time. If I had the correct pin insertion/removal tool it would be easy.
page 6
TheRedBox
31
Dec 2, 2003 04:53 PM
