xB: Removing front passenger seat
Hello. Can the front passenger seat be removed without damaging the chasis or seat itself?
Jerry
◄◄Click Here to Add your Vehicle to Garage
What does Garage is empty, Add now mean?
Jerry
Yes, 4 bolts and one electrical connector.
EZ, no prob. Fold the seat back forward and be careful not to scratch or gouge your door panels or door frame paint on the way out!
yeah easy to gouge
Oh yeah, the inner/rear mount has two!
i'll be sure to check my paint work carefully after i take mine back to have the dealer replace the carpeting on warrenty...thanks for the info about gougeing paint.
Yup, the seat mounts are sharp and there is little wiggle room to get the seat out of the car. Be sure to check the plastic door panels also.
Music City Scions
It's called covering all the stuff that can get scratched with blankets first.
Thanks for the replies. Actually, I want to remove all of the seats, except the driver's seat, of course. I'll be keeping the seats in storage for eventual reinstallation.
Since the Xb will be discontinued next year I suppose I had better buy one before too long.
Jerry
Jerry
be carefull tho... i had my passenger seat out for a bit... and for some reason the brackets got bent a bit... front 2 bolts line up... but the rears are off now, if line up the rear outside bolt.. the rear driverside doesnt line up and vice versa.
didnt haven anything on the seat while it was out... so not sure what happend...
if they are gonna be out for a long time, may want to set them on a couple pieces of 2x4s or something and botl them down just to prevent them from bending any
Sorry for bumping an old thread. But due to the SRS sensor in the seat, once you unbolt/unplug either of the front seats, you will need to take it to the dealership to have the SRS reset so it works properly incase you ever get in to an accident.
Sorry for adding to this like 10 years later lol but is their any diy to resetting the SRS light?
You will need an OBD SCAN Tool which is capable of resetting the SRS system...... Same way you would reset the Check Engine Light and the ABS Light.
TJ
27
02-08-2004 12:20 AM
