XB SPEAKER SIZE
Old Oct 20, 2004 | 03:38 AM
soulcracker's Avatar
Default XB SPEAKER SIZE
I was thinking about swapping out the stock speakers with aftermarket and running them off an amp when i install my subs and was wondering what size this speakers are? Any suggestions on brand to go with i was thinking infinity or memphis. I have 2 10 inch jl audio subs. also anybody one anything similar and stick with the stock radio just wondering if this sounds good with the stock headunit.
thanks in advance....
Old Oct 21, 2004 | 12:29 PM
redneck69's Avatar
Default speaker size
Both front and rear speakers are 5-1/4".
Tweeters are 1-1/2" or 2", I forgot.
You'll need speaker adapters for the front door, I recommend getting a set of speaker adapters from Scsoche... part #SAT6. The factory front doors are riveted to door, you'll need the speaker adapter to mount your aftermarket speakers.
Old Oct 21, 2004 | 03:43 PM
SuperCrunchyAction's Avatar
Default Re: speaker size
Instead of adapters, he can cut out the stock speaker from the stock mount and then use that for his aftermarket speakers. I know some people here have done this with good results.
Old Oct 21, 2004 | 03:50 PM
TheIcon's Avatar
I believe the tweeters are 4"
Front 6.5"
Rear 5.25"
Old Oct 21, 2004 | 04:14 PM
TokyoRaver's Avatar
That's what I did.. works great.
And I have 4" Infinity Kappa's in my dash. I think that's the biggest you can go there.
Old Oct 21, 2004 | 04:18 PM
BrockAbabba's Avatar
I put 6.5 in the door with no adaptor of any kind, and lotso dynamat!
4's in the dash, but had to modify the speaker to get it to fit. The tweeter height will be your nemesis. Get some nice low ones. Don't forget the bass blockers!
BTW i put 5.25 in the back easy, 6.5 could have been done.
Old Feb 25, 2006 | 05:44 AM
HungSolo's Avatar
Do you cut out the factory speaker without removing the mount? How did you cut it out and with what?
rain7905643
Mar 14, 2015 12:48 AM
meechindisbeech
Scion xB 2nd-Gen Wheel & Tire
12
Feb 28, 2015 04:20 AM
paolodoctolero
Feb 22, 2015 06:35 AM
blh72
Jan 31, 2015 03:41 PM
