xB Wiring Color Codes and Locations
I know alot of you will want this precious info :D
Its from a good source.. I will be installing an alarm in the next few weeks and will be taking questions from anyone who needs help. Anyways, enjoy: Scion XB | 12V|wht/blu and wht/red |+ |ignition harness | | STARTER|black |+ |ignition harness | | IGNITION|black |+ |ignition harness | | SECOND IGNITION|black/yellow |+ |ignition harness | | ACCESSORY|blue/red |+ |ignition harness | | POWER LOCK|blue/white *1 |- |driver kick, 14 pin plug | | POWER UNLOCK|yellow/black *1 |- |driver kick, 14 pin plug | | LOCK MOTOR|blue/orange |5wi|driver kick, 9 pin plug | | UNLOCK MOTOR|yellow/green |5wi|driver kick, 9 pin plug | | DISARM DEFEAT|blue/black |5wi|passenger kick, 9 pin plug | | PARKING LIGHTS +|green | |headlight switch *2 | | HEADLIGHTS|black/white |- |headlight switch | | DOOR TRIGGER|red/white |- |top of fuse box, 9 pin plug | | DOME SUPERVISION|use door trigger | | | | TRUNK/HATCH PIN|common with doors | | | | TACHOMETER|black | |data link connector *3 | | SPEED SENSE|purple/white | |back of fuse box,18 pin plug| | BRAKE WIRE|green/red |+ |brake pedal switch *2 | | HORN TRIGGER|white/red |- |steering column | | WIPERS|gry (L), blk/red (H)|+ |steering column | | LF WINDOW UP/DN|red/blu - grn/wht |A |driver window switch in door| | RF WINDOW UP/DN|red/blu - grn/wht |A |driver kick, 9 pin plug | | LR WINDOW UP/DN|red/yel - grn/yel |A |driver kick, 4 pin plug | | RR WINDOW UP/DN|red/blk - grn/blk |A |driver kick, 4 pin plug | | RADIO 12V|blue/yellow |+ |radio harness | | RADIO GROUND|white/black |- |radio harness | | RADIO SWITCH|gray |+ |radio harness | | RADIO ILLUMINATE|green |+ |radio harness | | POWER ANTENNA|black/red |+ |radio harness | | LF SPEAKER|pink - purple |+,-|radio harness | | RF SPEAKER|lt. green - blue |+,-|radio harness | | LR SPEAKER|black - yellow |+,-|radio harness | | RR SPEAKER|red - white |+,-|radio harness | NOTES: *1 Meter these wires while turning the key in the driver door key cylinder. Unlock requires a double pulse. Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/red (-) in the passenger kick in a 14 pin plug. *2 Also found at the top of the fuse box in a 13 pin plug. *3 The data link connector is below the fuse box. The tach wire is in pin 9. __________________ |
darren should put this in FAQ...
looks like many of you are looking for this |
I know this is important stuff.. I just dont understand it. I need a diagram.. :cry:
Hey Inazuma, do you also do installs for others? Recommend any good alarm systems? Don't think I wanna pay $400+ for the factory one when there's better ones in the aftermarket.
Thanks! __________________ |
:shock: This stuff is great, now, I really need to know this one. I need the instrument panel lighting, the one that dims, for my guage trio, right now their on a switch i put in the center console....real cheesy. this would be a great help if you know it....Thanx, See Ya, Louie 8)
Originally Posted by G-Force
hey inazuma, do you also do installs for others? recommend any good alarm systems? don't think I wanna pay $400+ for the factory one when there's better ones in the aftermarket.
Thanks! I used to install before, but i am older now. I got sick of it. But let me see how easy/hard it is to install in the xB. Maybe i can walk you through it. I will install mine around X-Mas break. |
is there a constant positive in the rear of the car?
I'm gonna use this wiring diagram for my xA's sub.. tell me its teh same! I'd assume so.. but arnt 100% sure. Anyone know?!
great info! this will be very usefull to many of us
I Have done 4 xB's and several hundred alarm installs under my belt,
I can be help in someone needs it just shoot me a PM. -Bill __________________ |
Should anyone come across the wiring manual for the xB I would suggest buying it. It contains everything you need for wiring and tapping into the factory wires. Color codes, harness locations, ground points and power points to name a few. I got mine on eBay for $30.00. Well worth it. :lol:
Here are a couple of tips I think may help you guys in your install.
1. Most of the wires you can find either infront/on the top or behind your fuse panel. From your 12V/Ignition/Door Trigger/Parking Light ETC. Makes for a cleaner install. 2. Use a DMM (Digital Multimeter)and not a testlight. 3. There's a good spot above (all the way up the AC vent) the Driver's kick panel to put your alarm. Just my two cents, Hubert __________________ |
Geat tips to live by a an installer. I also use the same location. Bill
so, if i read this correctly,
| RR SPEAKER|red - white |+,-|radio harness | would mean that the radio harness has a solid red wire taking positive to the rr spk, and a solid white taking negative, is this correct? |
The real deal.
PM me with an email addy and I can send you an official complete overall electrical wiring diagram (in PDF) for the xB. I also have Bazooka Wire Harness & Radio Wiring Schematics. 8)
*saving for future reference*
Looks like Direct Techs to me...I was going to post that a while ago, just got too busy.
Anyhow FWIW I have a couple USAC, IASCA, and DB Drag World Championships under my belt, I suppose I can contribute to the community if anyone has questions regarding alarms, installs, techniques, and general stereo questions. Keep in mind I haven’t been too active in the car audio world since about 2003, but not much has changed regarding application. Then again I’m sure there are plenty of more current car audio people on here, but I’m available to help. Maybe I should have started another thread for this…didn't mean to rant and hijack the thread..sorry :nails: -Chris |
Side mirrors?
Anyone know what color is what for the side mirrors to move the mirror up and down left and right?
Tell me you're still around doing this kind of stuff?
Originally Posted by Inazuma
(Post 9554)
I have hookups for alarms even with automatic start and the ones with the little keychain pager (two way) Let me know what kind u r looking for. I can probably hook u up also. I live in Torrance area.
