Xbox in an xB
Originally Posted by Digicon
can u see the wires? And i have a modded case on the xbox it looks bad ___. Lol
planning to do mine under the front seat.
I'm going to mod my xbox to use a power switch (one of the gardner bender's from lowes) and put a hard drive in it so that I don't actually need normal access to it. I'll have the network connection accessible so I can pull in the garage, hook it to the network and transfer files if necessary though.
just to help you all along for modding needs if you dont know about this site already www.xboxscene.com for all and i mean all for your xbox modding needs
What size power inverter are you guys using to power your x-box, becuase wheb i turn on my xbox my 350 wattt inverter beeps and then shuts thew xbox off. But then when i turn the car on it works fine. I want to know how i have to set it up if i want to0 play the xbox withoutn the keys in the ignition.
Oh yeah and BTW i put my xbox under the passenger seat and i built a little carpeted box fir it so it sits straight. It looks nice and ity also hides the helps to hide the wires and the power inverter.
Shouldn't be necessary if you are only running an XBox, but you might try running the cables (or new cables) directly to the battery. I'm probably going to do that on mine, but I'm going to be running a larger than necessary inverter (700w, 1500w peak most likely).
Originally Posted by Pooka
If you really wanted to go kickass... get the wireless xbox adapter. THAT would be sweet. See if you can drive around and find open wireless networks to play on. And it would keep you from needing to run a network cable into your garage.
The wireless adapter is a good idea, but the xbox and it's networking ability is a bit flaky. It would probably be more of a pain than it's actually worth... consider my network connection will be just to transfer mp3s/movies from my network.
You mean everyone doesn't already have a computer and network connection in their garage?
