15 offset or 0 offset??? Sitting on DF210's
Old Nov 20, 2007 | 05:45 PM
Bossman's Avatar
Default 15 offset or 0 offset??? Sitting on DF210's
hey suspension guru's i have a question. Im going back to 15" wheels and cant decide whether or not I should go for a 15 offset or 0 offset on the sportmax wheels. I will have the car on Tanabe DF210's by the time I get the wheels and just dont want to rub, trying to keep my daily driver issue free. Looking at 15x8 unless the 15x7's are better for the lowered suspension. So offset recommendation is what?...
let me know guys on what you think! thanks for the info.
Old Nov 20, 2007 | 08:17 PM
burstaneurysm's Avatar
0 offset is gonna poke out. You'll probably need to roll the fenders.
I'd go with the 15.
Old Nov 20, 2007 | 08:23 PM
sizzlinscion's Avatar
i have the 0 offset wheels and they will poke out alittle bit and you will need to roll your fenders to run them without rubbing.
Old Nov 20, 2007 | 10:23 PM
Bossman's Avatar
well i forgot to mention...i had sportmax 002's in a 0 offset before. I loved the poked/stretched look but since then im going to lower it so I was curious if I would still rub with a 15 offset
Old Nov 21, 2007 | 01:06 PM
swartzautoman's Avatar
good to know.
im on tein s-tech with 501 15x7 38 offset and im about to change to 501 16x8 15 offset.
ive got the echo stuts up front and a 20mm OTG in the rear.
i know ill have to remove the OTG but im hoppin evey thing elts will be ok. the other thing i was thinkin was maby use the TRD springs in the rear.
Old Nov 21, 2007 | 03:06 PM
15 should be fine on everything but the biggest bumps. Without the OTG spacer, you should be golden in the rear... I say, leave it in!
Old Nov 23, 2007 | 03:00 PM
Narcolepsy123456's Avatar
i'd say you're going to have to roll your fenders for sure, but everyone should do this as it will allow you to run lower offset wheels with no rubbing.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
eujin
Feb 23, 2016 01:18 AM
jthistle
Oct 5, 2015 09:32 PM
terrye
Sep 26, 2015 12:24 AM
