cuttin springs??
sry he didnt let me get that far, i guess someone else is gonna get my money. I will get a firm answer from the dealership when i get the wing installed. And ill reply to this thread if he gives me anything better than at point of sale price. My dealership is very concerned with customer satisfaction and refuses to sell me something that i wont be happy with. I feel like a kid in a candy store and the cashier say's you dont want that it will rot your teeth. Ill let you know george_da_2nd
kms2112
kms2112
actually... if you have the space and tools.... it shouldnt take more than 30min for you to install springs your self...
i believe the rear is similar set up to the xB.. its litteraly 1 bolt for each side to undo after you jack the car up...
front is a bit more time consuming but again pretty easy...
impact wrench is recomended for the fronts to break the bolts loose.. plus you have to take off the front tires.
regular socket wrench should get the rear bolts off... and you can leave the rear tires on
a torque wrench is a must have the bolts and nuts on the knuckels need to be torqued down too 97 ft lbs
the center nut on top of the strut is 25 ft lbs
3 nuts on top 29 ft lbs
nut on the rear shock gets 36ft lbs
this thread here has a great walk thru/diy
https://www.scionlife.com/forums/viewtopic.php?t=20769
Music City Scions
I've done several sets of springs and have it down to 45 minutes. Remember... It's not the springs that make the ride harsh. It's the stock shocks in the rear. They need to be replaced with the Monroe Sensatracs.
Music City Scions
Originally Posted by george_da_2nd
can the stock shocks take the one inch drop?
Find a nice progressive rate lowering spring and you'll be happy. It'll ride like stock and give you the drop you want.
I'm running Ksport springs (cheap from elementmotorsport.com) and I'm quite pleased with the ride. Still on stock shocks/struts. Ride is almost like stock, until you hit a bump or toss it into a corner. The improvement in handling/looks is well worth it.
price is also a factor how much would my toyota dealership charge me to put on the trd springs and how much do you think it would be if i went with a decent aftermarket set of springs installed at lets say les schwab
Music City Scions
Remember you'll also want the monroes for the back with whatever springs you end up with.
Honestly, it's quite simple to do it yourself, even with little know-how. Just get a buddy and so some research on these forums, and it can be done in under an hour. It's certainly more fun than paying someone an arm and a leg to do easy work for you.
ok george_da_2nd, i went to the dealer today to check on my spoiler i ordered and i asked the service rep and he said $600 labor plus parts. WT? anyway i asked my salesperson and he said it was $330 for parts and install and to get him when i want the springs installed and he would battle with the service rep. If i would have known that i could get them installed for $330 i would have ordered springs when i ordered my wing. Sales person said that the service rep is toyota and does not understand Scion pricing. When i let them fight it out ill repost on the winner.
kms2112
kms2112
Well im capable of doing it. I took a cradle from a 88 Fiero and stuffed it in a 87. They are not compatable because lotus redesigned the rear suspention for pontiac in a effort to save the model. 84 thriugh 87 were front wheel drive units from the sunbird with the tie rod ends locked to the frame. the 88 was a trailing arm set up designed by lotus. I had modifiy the struts to get the alignment right. I dont have access to the garage that i had then. If there is a local club in indy that helps each other out im in. But im not gonna take my car apart in the driveway. I guess i got old and tired to soon. I would pay someone to do it so if it messes up im not to blame.
kms2112
kms2112
