Energy Suspension End Link Bushings installed!!!!
I was browsing a ES site and for the sway bar bushings there are 2 kinds the greasable and non greasable. I want the non greasable ones but for the 25mm bar there are 2 different ones. It has to do with the measurment of the spacing of the bolts. Part # 95129 has the spacing measured at 2 1/16" to 2 7/8". Part # 95110 has the spacing measured at 2 9/16" to 3 5/8". Which one is the correct one?
http://www.energysuspensionparts.com...20Bushings.asp
Originally Posted by dexter_5000
what is the master kit gonna conclude?
Originally Posted by bb384
Just a heads up... Full energy Bushing kit coming soon! They R&D'd my car, I just picked it up earlier today, with 95% of it installed, right now I'm waiting for two bushings to be finalized and my car goes back to energy for the final bushings to be installed. The kit includes; Motor mount inserts, sway bar bushings, sway bar endlinks and bushings, front lower control arm bushings, rack and pinion bushings, and torsion beam bushings. The R&D guy saw the endlink kit that I put together using this write up and he said it was okay, but he made a better set up.
Originally Posted by moderngti
What does this mean?
"the master kit makes my car ride like its on coilovers"
Originally Posted by BoiseAuctioneer
So does this do any good if you do not have a aftermarket front strut bar?
i just did mine and wow, it a real difference,
i find myself turning the wheel too far because of the quickened steering. anyone else have this effect.
i put a locking nut on each one, but i am always afraid it will come apart, whenever i do anything, i tightened it to where i couldnt anymore. so hopefully they stay.
it was kinda difficult with just stands, because i am too big to fit under mine, (lowered) and when jacked, there was too much pressure
so i ended up taking both wheels off and doing one side at a time, and jacking up the control arm. this was a great $15 mod, even with having to buy grease, lol
I found the bushings to be pretty easy but the links were a bastard. A lot of prying and a little hammering but they are in there and it feels great. I cant wait to get back out on the autox course again.
These are alot of wild claims for just end link bushings. They will make your front sway bar work alot better due to the lack of deflection from the rubber bushings, that's about it.
Making your front bar work better will increase the amount of understeer your car has and there-for make it handle worse, since these cars are prone to understeer. It will also keep the car more level in the front in hard turns, which may make it feel better.
You have to get the rear sway bay stiffer to really have some fun. The front chassis brace is also a huge improvement.
Has anyone just bought the urethane and not the kit? I am talking just the bushings. You should be able to replace just those and use the stock bolt.
I wonder how delrin would work instead of urethane, for both the sway bar bushings and the end links. Has anyone used them like this before?
Read the title to the topic. Its a known fact that the bushings are the main reason why you want to change out the endlinks, usualy the bolts and washers are there to acomodate the bushings.
Making your front sway bar will not necessarily increase understeer, it will increase steering response, and therefore make it handle better. You are right about the car being more level in turns. Just my $0.02
and if you have soft / stockish springs... and toyota camber bolts for about 1 - 2* or negative... more front bar stiffness can lead to better cornering as it will help keep te outside tire from losing camber as quickly under compression, in our Mac-Strut cars...
It will also make the inside tire un-weight more and force the outside tire to work harder, causing more under-steer.
Changing the caster will help alot more than the camber.
Agreed that caster is good... but you NEED static -ive camber... and a front bar will help preserve the camber is you load it up...
Ideally... you'd lower the car, ball-joint extenders, longer control arms... stiff springs, adj. camber / caster, etc...
But for a soft sprung car... a slightly stiffer front sway... won't kill the car... and with enough -ive... can be a good thing.
Does anyone actually drive their cars to the limit to test it out for sure?
I know when I push my car it does understeer. When I get off the throttle the back end of the car comes around.
Your classes may have taught you everything, but what I say I have done. I have been driving hard for quite some time. I built and tuned my last car, where there is little to no aftermarket. I also drove the living crap out of it.
ok people i just installed the bushing kit last night i have to say its the best performance mod for the $15 my suspension is stock other than the bushings and they made a big difference installation can get tricky
heres a pic of oem and the energy bushings
heres a pic of them installed
i know it looks funny but thats only cuz the car is on jacks but i ensure you its installed correctly
energy bushing kit $11.99
2 - 4'' grade 8 bolts $1.78
2 - grade 8 lock nuts $.78
moding the box for under $15 priceless
