Front brake question
Old Aug 14, 2007 | 04:09 AM
Super-Stormtrooper07's Avatar
Default Front brake question
Does anyone know what the stock oem front disc size(diameter) is ?
Also, if I went to a larger disc up front, does anyone know if I can still use my stock caliper ?
Thanks in advance.
Old Aug 31, 2007 | 09:56 AM
bB2NER's Avatar
Music City Scions
Caliper, Pads and rotor are a set size/diameter. You'd have to upgrade everything.
Old Aug 31, 2007 | 04:19 PM
Gotcha!
Just got word that if I end up going with a Power-slot roter .. the are automatically 1" bigger then OEM. That will probably be the route I go , w/ a nice Hawk pad , or TRD pad.
Old Sep 2, 2007 | 02:56 AM
bB2NER's Avatar
Music City Scions
I checked out powerslot rotors and they are a direct replacement for the stockers. If they were an inch larger they would prohibit the calipers from mounting up and drag on the calipers.
Old Sep 2, 2007 | 04:16 AM
Wow,
I guess my source gave me mis-info. then!
Thats fine though, that would still be the route that I'd go- power slot + some good pads.
Old Sep 3, 2007 | 01:07 AM
streetlethalxb's Avatar
The slotted/drilled rotors sold specifically for the box are stock size. They are direct fit. If you did get a bigger rotor, you would have to do what tuners did back in the day.. custom build a bracket to place the caliper at the correct hieght for the big rotor. I just ordered slotted/drilled rotors, front and rear braided lines, project mu pads, and Motul RBF 600 fluid.. will post up after the install.
evolving_machine
Oct 21, 2023 01:16 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
toyotaisme
Jan 10, 2015 10:24 PM
JPuehl
Jan 10, 2015 01:01 AM
TheTripleC
Jan 4, 2015 06:46 PM
