How to remove calipers?
Old Mar 9, 2007 | 03:26 AM
mad-sciontist's Avatar
Scion Dynasty
Default How to remove calipers?
Hey everyone, does anyone know if their is a walkthrough on how to remove the calipers on the xB??? I tried searching but couldnt find one.... Thanks!
Old Mar 9, 2007 | 10:19 AM
J1slim's Avatar
yellow arrows= caliper bolts
green arrows= caliper mounting bracket
Old Mar 9, 2007 | 07:09 PM
SLOW4point0's Avatar
what are you planning on doing?? If you are njust changing the pads then you should be able to just pull out the caliper bolt and slide the rails off. If you are changing the rotors then you will have to remove the whole thing.
Old Mar 9, 2007 | 07:56 PM
06ShadowBoX's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=55431
Old Mar 10, 2007 | 02:24 PM
Scion Dynasty
Well im going to be painting them... Not with one of the kits either, i got some spray paint that im going to be using... So i wanted to remove them..
Old Mar 10, 2007 | 05:03 PM
JakAHearts's Avatar
Just a quick question, are the pads in the Xb (i have an Xa) shaped odd? When I had my wheels off last I look at the pads to make sure I didnt need new ones and they looked like this. _/ \_ Is there supposed to be a raised section in the middle?
Shane
Old Mar 10, 2007 | 10:12 PM
kimgt's Avatar
can you be more specific? were the ends kinda tapered off, cause i think thats normal.
Old Mar 10, 2007 | 11:08 PM
J1slim's Avatar
the pads will have a slot in the center and taper at the ends
wejarrell
10
Aug 5, 2015 09:19 PM
gqdabien
Jul 22, 2015 10:30 PM
nightwitch
Jul 14, 2015 01:58 AM
excessads
Jul 13, 2015 11:41 AM
Tak16
Jul 7, 2015 05:45 PM
