Installed springs on rear and have questions
Hello,
Today I installed the rear lowering springs on my xB. I only go tto do the rear because the sun was setting and I knew if I started the fronts it would get dark and of course something would go wrong. That's just how it goes. Anyway...I'd put pictures up but don't have the camera here. Question 1 The tightly wound part of the spring sits on the lower perch correct? Question 2 The top rubber bushing is sitting like 90% on the spring. I drove around and hear no noise or feel any problems. I will be pulling wheel off soon as it is a spare and I will check if anything is wrong then. I am just wondering...should I go and put the bushing 100% on? The spring is not coming out an dis seatd fine in the mounts...just a little bit of the rubber isnt over the spring. Thanks for you help! -Brian! |
BUMPY!
there is groves that the spring should fit into to let you know you did it right...inspect next time you get a chance...
