Installed springs on rear and have questions
Old 01-07-2006, 09:37 PM
BrianGillen's Avatar
Default Installed springs on rear and have questions
Hello,
Today I installed the rear lowering springs on my xB. I only go tto do the rear because the sun was setting and I knew if I started the fronts it would get dark and of course something would go wrong. That's just how it goes.
Anyway...I'd put pictures up but don't have the camera here.
Question 1
The tightly wound part of the spring sits on the lower perch correct?
Question 2
The top rubber bushing is sitting like 90% on the spring. I drove around and hear no noise or feel any problems. I will be pulling wheel off soon as it is a spare and I will check if anything is wrong then. I am just wondering...should I go and put the bushing 100% on? The spring is not coming out an dis seatd fine in the mounts...just a little bit of the rubber isnt over the spring.
Thanks for you help!
-Brian!
BrianGillen is offline
Old 01-09-2006, 05:01 PM
BUMPY!
Old 01-09-2006, 06:58 PM
TheDanger's Avatar
there is groves that the spring should fit into to let you know you did it right...inspect next time you get a chance...
TheDanger is offline
TotalChaos
13
02-04-2015 10:24 PM
kleecker
01-09-2015 02:26 PM
fluxingnation
12-26-2014 04:28 PM
PTUNING
12-11-2014 08:09 PM
PTUNING
12-06-2014 03:58 PM
Quick Reply: Installed springs on rear and have questions
