Installing Rear OEM Springs..
Hey y'all. I've "de-lowered" my '05 xB and reinstalled the Factory Springs. But, now, I'm wondering how the Rear Springs get installed.
There are little, red dots strategically painted on them...but, what does that mean? Are they s'posed to face Inboard, Outboard, Fwd, Rear?
Anyone know? Thanx.
V/r
Scott
Anyone know? Thanx.
V/r
Scott
Thanks for the Reply and pdf. What's weird is each spring has TWO paint splotches on them (one over the next) and while they are "near" the bottom, they are actually closer to the center coils on the spring. I'm pretty sure I have them oriented as far as top & bottom goes.
Also, the wording on that note: "Be sure to install the coil spring so that the paint mark comes to under the vehicle." WTH does that mean? I could interpret to mean, facing inward.
I've look at the wear marks of the upper & lower spring insulator rubber, but they're inconclusive. Messing with it, I can talk myself into rotating several different scenarios.
Would you happen to have the Manual section for the Front Coil Springs? They have paint spots on them as well and it's probably the same marking convention (I can check later today, too).
Thanks for the help, @MileHightC.
The orientation of the OEM springs is usually not too big of a deal as they're linear in most cases. If one side is wider than the other, see which way it makes best contact in the suspension setup. Also make sure the ends of the coils butt up against the perches so everything is tightly secured and has a minimum chance of making noise. If there is any text printed on the spring, that generally signifies the orientation of the spring (should be right side up). You will need spring compressors to install the fronts.
Thanks. Fronts are 'in'. The top of the strut mount makes make it easy to figure out spring orientation. The rears are installed and I've ordered new lower insulators (present ones are torn) and I'll work on this again.
Anyone know? Thanx.
V/r
Scott
Anyone know? Thanx.
V/r
Scott
drewspeed
Aug 28, 2006 05:33 AM
hawaiian_xB
23
Mar 7, 2005 03:59 PM
