Monroe Sensatrac 5870
Old 03-05-2007, 07:42 PM
jonnyd's Avatar
Interesting, when I do a search for the shocks at Advanced Auto Parts, it shows the 5870s but says they are not available at this time.
Is anyone else seeing this? I can stop by local but wanted to check on availability in Tampa...
jonnyd is offline
Old 03-06-2007, 12:03 AM
ReyS739's Avatar
Yeah I saw that...I went to the store and they had to order mine they said it would take a day...luckily they were in stock in their wareouse. I got the last ones in my warehouse closest to me but I know they have some in lakeland or lakeworth fl so you should be ok.
ReyS739 is offline
Old 03-06-2007, 12:08 PM
Alchemist80's Avatar
Yeah, they were out of stock in my area too, i got a Georgia and a south carolina shock Oh well. I have them, they are installed and i couldnt be happier.
You can see from the pic that the new shocks are a little shorter than the old ones and about twice as thick....
Alchemist80 is offline
Old 03-06-2007, 12:32 PM
Originally Posted by urbanhayseed
on the subject of Monroes - I just had mine installed today (on a Sunday!) at a reputable local shop: $240 for two rear 5987s (installed) along with installation of a Progress rear sway bar. i only drove 3 miles home in slow traffic, so it was hard to tell if there was a difference. i'll find out more tomorrow.
my question is this - when i got home, i noticed the shop didn't send me on my way with my old (3,500 miles) oem shocks. should i go back tomorrow and get 'em? are they worth anything?
Always get your old stuff back. You never know when you might need one as a replacement. Also, it only took 15-20 mins to change these things.
Old 03-12-2007, 10:53 PM
ReyS739's Avatar
I couldn't put on the shocks (5870) with the stock equipment Tom explained on the first page. The bolt wasn't long enough I used the bottom part then I used the rubber piece and washer that came with the shocks for the top...
ReyS739 is offline
Old 03-14-2007, 12:01 AM
YellowSubxB's Avatar
Just had a pair of Monroe 5987s put on the rear of my 2005 R.S. 2.0. xB. Both I and My wife drove it around on some bumpy roads and there is definitely a difference. BTW - we have about 30K miles on the car now.
One other point - My mechanic's distributor could not find the shocks listed under the Scion xB but, as stated previously, under the Echo.
Worth the investment. (Now I have to decide if we want to do it on our two other xBs.)
YellowSubxB is offline
Old 03-14-2007, 12:39 AM
burstaneurysm's Avatar
I'm sure you've already done this, but you should go back and get your stock stuff.
240 for the part plus install? Ouch.
burstaneurysm is offline
Old 03-14-2007, 11:30 PM
thegoatlord's Avatar
wow, i think they gave me the wrong thing when i compare the pictures from above to what i have.
the part number was 55870, and saws its gasmatic, and not sensatrac.
lemme guess, i eff'ed up didnt i?
thegoatlord is offline
Old 03-15-2007, 12:50 AM
Admin Emeritus
Tomas's Avatar
Uh, yeah, 55870 != 5870
Tomas is offline
Old 03-15-2007, 12:56 AM
well, hopefully i can get my advance auto to take back my order and order me some 5870s then
i went with what you had posted previously when i asked how to get the 5870s, and thought they might have just messed up and added another 5.
silly websites :D
edit: damnit, now theyre out of stock! NOOOOOOOOOO!!!!!
Old 03-16-2007, 12:29 AM
kewlbox's Avatar
I just put a set on last night, And they make it alot better ride on the ruff roads.
I am on hotchkis right now for a 1 1/2 inch drop, soon going to df210's for a 2 inch drop.
Well worth the $44 dollar investment.
kewlbox is offline
Old 03-16-2007, 03:58 PM
JDMbB83's Avatar
So is it the 5870's for the front? Im confused.
JDMbB83 is offline
Old 03-16-2007, 06:23 PM
kewlbox's Avatar
5870's are for the rear. You should go and get a pair of them and put them on for a smother ride.
I put mine on in under 20 min, and i only jacked up one side of the car. Jacked up the drivers side and put that one on, and looked at the other side and decided just to reach under the car and do the other side right away. shocks are simple to change out.
kewlbox is offline
Old 03-16-2007, 08:01 PM
Admin Emeritus
Tomas's Avatar
5870s are an option ONLY if you have lowered your vehicle 2" or more, otherwise the 5987s are the much better choice, since they mount and fit the same as the OEM shocks (the 5870s do NOT).
Front struts are a different deal entirely...
Tom
Tomas is offline
Old 03-17-2007, 04:15 PM
JDMbB83's Avatar
Im running a 2 inch drop. But what should I use for the front?
JDMbB83 is offline
Old 03-17-2007, 07:10 PM
Admin Emeritus
Tomas's Avatar
Sensatrac front strut # 71575 originally for the Echo sedan.
This will add 1/2 inch to your front drop, however, since the spring perches are mounted 1/2 inch lower on the Echo strut.
By the end of the year there will be Sensatracs designed specifically for the xB - see the post about that on page one.
Tomas
Tomas is offline
Old 03-22-2007, 09:54 PM
SuperMario6582's Avatar
ok so i got me some 5870s today. i havent changed out a set of shocks in years. this will be the first time that i am changing the rear shocks on the xb. what will i need to do to make this install as simple as possible?
SuperMario6582 is offline
Old 03-22-2007, 09:58 PM
jonnyd's Avatar
Find the tech article on replacing the rear shocks with the Koni's in the Tech area. Use that and Tomas's info on the first page of this thread and you will have them changed in less then 30 minutes. Only thing that they don't mention is you really need deep 14 and 17mm sockets.
Good luck!
jonnyd is offline
Old 03-22-2007, 10:06 PM
cool man, thanks.
Old 03-24-2007, 11:05 PM
got them installed today. thanks to tomas for the picture of the shocks. it made the install a lot easier. install took abour 20 minutes to do.
Quick Reply: Monroe Sensatrac 5870
