Need Help! Problems AFTER installing the Anti-Sway Bars
Old Sep 7, 2004 | 06:27 PM
WileECoyote's Avatar
Default Need Help! Problems AFTER installing the Anti-Sway Bars
Topic: Wierd Cabin noises after installing Hotchkis FRONT anti-sway bar.
I couldn't bring the subframe down myself (no lift) to get the subframe off. A shop here in Honolulu said they'd charge me $80 to install the front ASB. I figured money well spent.
During the install, they dropped the subframe too low, and the rod that connects the steering wheels to the rack or what ever came out, and lost steering control. They spent the next two hours getting the rod back in, and the splines lined up so that the vehicle tracks straight.
However, now when I drive the car, and get lots of extra road noise. I can hear gear whine when accelerating, and all kinds of stuff I didn't hear before. Its very subtle, but I know it wasn't there prior to this install.
Does the front anti-sway bar cause this extra noise? (added rigidity causes more noise transmission...)
or is it because the shop messed up something on their install?
ANY help is appreciated here. Please chime in all you mechanics!
Old Sep 10, 2004 | 10:38 PM
cummon, someone must know something...
Old Sep 11, 2004 | 09:30 PM
Minsk99's Avatar
It is because they ____ed something up. There should not be any kind of "gear whine" noise due to the sways. Bring it back to them and insist that they fix the problem.
Old Sep 11, 2004 | 10:08 PM
mmintegra's Avatar
sIcKsCiOnS
I'm not sure what shop you went to, but can I suggest WMR to you? Go and see Johnny, the owner, he's a good guy and will take care of you. I spend a lot of time in 808. My cousin lives out there and used them for his S2k, Civic, and Blazer. It's a really good shop. I wish they had something like it here in Mass. He hooks me up with parts all the way in Boston though. Good luck!
Old Sep 13, 2004 | 05:22 PM
Wide_tC's Avatar
If the install shop did not remove the rack bolts and pulled down on the subframe it will pop the dust boot off that goes around the steering shaft that is at the firewall. It is actually pretty common to happen. Most shops think they can do shortcuts and don't see a problem with not disconnecting the rack.[/quote]
Old Sep 13, 2004 | 05:36 PM
superjeer's Avatar
A little off topic.. But, I think it's pretty cool that someone from hotchkis would get on here and respond to this thread in a useful way.
Old Sep 14, 2004 | 10:22 PM
[/quote]
Looks like that was the problem. Hotchkis is awesome. They would be even more awesome if they put those kind of warnings/instructions in their installation manual... ;)
Thanks for the help!
btw, the Hotckis springs has a nice even stance, and enhances grip. I didn't think that adding the Front Anti-Sway bar would have that much of an impact, but it is definately noticable. Great products. Please send me my free Hotchkis stickers so I can put it on my car and give you guys free endorsements. ;)
Old Sep 16, 2004 | 02:26 AM
Guest
Guest
Posts: n/a
[/quote]
Beat me too it!!Good call!! I was about to post that when I saw the topic and scrolled down and saw you replied. Thats freaking awesome to see you online!! I was tired of being the only one online to help out with these botched swaybar installs.
Old Sep 16, 2004 | 02:30 AM
Greenmnkey's Avatar
OhioScions
What exactly does a sway bar do, dont know much about add-ons and stuff....
Old Sep 16, 2004 | 02:53 AM
bB2NER's Avatar
Music City Scions
It counteracts the leaning that takes place when you go around a corner ,the bar is connected to each of the front suspension arms and the car tries to twist the bar as it corners
Old Sep 16, 2004 | 02:57 AM
Greenmnkey's Avatar
OhioScions
Makes sense, is it a sawy bar or anti-sway bar? Both? Excuse the ignorance here...
Old Sep 16, 2004 | 03:21 AM
superjeer's Avatar
yeah, Anti Sway Bar is what they really are.. but people just call them sway bars, even though then it's a bit of an oxymoron, eh?
Old Sep 16, 2004 | 12:10 PM
Greenmnkey's Avatar
OhioScions
Thanks for clearing that up, so whats the difference in bars? One is more rigid than the other? I know racing suspension are more rigid right? A little bit harder of a ride?
Old Sep 16, 2004 | 09:35 PM
Anti-sway bars don't really affect ride quality.
They help weight transfer of wheels, and overall cornering balance. Ride quality will be affected more by springs and struts/shocks.
Old Sep 16, 2004 | 09:42 PM
neckbonenick's Avatar
so williecoyote did you fix the problem?
Old Sep 16, 2004 | 11:29 PM
Buebie's Avatar
MN Scions
Plus there is a weight reduction to installing the Hotchkis. The stock front sway is pretty damn heavy.
Old Sep 16, 2004 | 11:35 PM
Greenmnkey's Avatar
OhioScions
This i9s my first new car, so I am anxious to put some time an dmoney into it (money i don't have) My other cars were not worth putting any money into.
Old Sep 17, 2004 | 11:04 AM
Yeah, I think they fixed the problem.
Hey guys? Is it hard to locate the boot myself? Can I see if from the inside of the car, or do I need to get my car back on some stands?
Old Sep 17, 2004 | 09:34 PM
wesley_t's Avatar
[/quote]
Maybe you can answer my question about what size Energy Suspension or other brand endlinks I should use on my XB since I have the Hotchkis sways? I tried emailing before but was told you didn't make endlinks
I just want to get rid of all extra the sounds I hear from suspension
Old Sep 18, 2004 | 03:54 AM
I think adding poly-urethane bushings will cause more clunks and creaks than rubber.
