Progress Tech's Rear Sway Works!
FYI, we offer the Hotchkis Tuning Sport Anti-Roll bar set. The bar diameters are 29mm Front, 13mm Rear. The front bar is hollow and rear bar is an add-on bar that is designed to work in conjunction with factory bar. Includes greasable bushings and mounting brackets. For more information, please visit our site at:
http://www.tirerack.com/a.jsp?a=DJ1&...sion/index.jsp
The xB does not come with a factory rear sway.
Originally Posted by LeeD
fyi, it looks exactly and installs exactly the same on the xA.
I bit of a pain to install if you've anly got one person, but installable. I installed it myself alone in about 15-20min. Included some cussing too. ; )
how thick is the progress rear bar?
the thing is great I highly recommend it.
However, now that its settled in i'm noticing a bit more body roll (than when i first installed it),
but that is probably b/c i'm cornering more aggressively or getting used to the ride with it on.
Strange. You should not feel much until you push the car in a corner. You should feel a reduction in roll (especially on the XB). The primary difference I felt was that the car does not plow (understeer) through corners near as much. Understeer causes your front wheels to lose grip well before your rear wheels. This is the way most FWD econo cars are set up from the factory because it is safer (more intuative to correct the "overspeed" situation with brakes and steering). Maybe the extreme understeer that I noticed without the rear sway bar was because my car was lowered. Don't know. You should recheck the torque on the nuts after a few miles. Good luck.
and i loc-tite nuts and bolts together
Originally Posted by hornet_on_flower
well the only time i can get extreme understeer is while in the snow and it hasn't snowed in a long while
The stock XA does have more neutral handling than the stock XB. The handling improvement would be more apparent in the XB.
I wonder if this bar is too much for the XA? You don't want to have so much rear sway bar that it oversteers (unless your a rally racer). Anybody experience oversteer with the rear sway bar???
The XB with this bar ends up pretty neutral.
wooo-weee!! just installed this sucker last night, took an onramp faster than i have and did not even roll, man this thing is awesome!
i actually look forward to merging onto hwys now... how lame
