Project: G.R.I.P (brace yourself!!!)
Originally Posted by milesm4
When you go to auto-x do you remove any of the interior or change tires?
Originally Posted by Scibox
Nope. The xB has traction control. Everything is still connected. I'll disconnect the abs before I autocross though.
I've never gotten a VSC light. What year is yours?
I'm pretty sure the two systems use the same warning tone and light....kind of yellow in the light cluster....I get the light in the snow when getting wheel spin,also get the light when taking a corner really hard with no wheel spin.
You stated before you werent able to break loose the back end.....and you wont....all these braces are doing is stiffing the body up not the suspension....there is no inducing of oversteer here....all it will do is when you go over bumps and large cracks in the road make it feel more solid....that is all
This is what ALL upper braces do....they do not interfere with handling at all
Under braces are a different story if they are attached to cross members and control arms and such
I've done "seat of the pants tests" so far and I like the results. I haven't been able to get the rear to break loose yet, but I'm still trying.
They are bars from other cars that I fabricate to fit our cars. It's a tedious process. There's alot of measuring involved. The company that I get the bars from have them in various lengths. After I do all of my measuring, I take that to the company and get the bars that I need. If it's too long, I cut it down little bits at a time until it's perfect. Since I get a company discount through my sponsor, I don't have to pay retail for them. Again if you want them, pm me.
Just got my bars last night, they went on really easy. From what I can tell they work, it's been raining so I can't really get crazy in the corners. But there used to be a little squeak from the plastic panels in the rear hatch now it's completely silent. Thanks Scibox!!!
i spent only 104 a wheel for my low offset 15X7's..
you just gotta do your research
there is a bracket attached to the frame just above the rear strut. it has some bolt holes in it. i'm not sure if it's welded or stamped on, but that could be a mount point. i didn't look closely for the purpose of braces when i had the plastic off this weekend :/
is the strut bolt in the rear a good mounting point?
no welding involved?
i've been thinking about putting something in there too, but i want mine to be easily removable for cargo.
