question on strippin my fenders
i'm getting ready to strip my fenders. so i can fit into 15x8 +0 offset sport max 002 wheels with 205/50/15 tires. is it necessary to strip the fenders on the fronts or just the rears?or will i need to do all four corners?
Originally Posted by micaxB
what do you mean by stripping fenders? taking them completly off or are you rolling them?
http://www.onetongarage.com/products...him/index.html
will they cause me not to rub with a +0 offset wheel? do tires wear at a accelerated rate?
But if you already have 0 offset wheels.....They probably won't help as the camber shims add positive offset and you are already outside the wheel well. Why 0 offset?
cutting your fenders wont make a difference. The wheel sticks out past the fenders. All you will be doing by cutting the fender is making a sharper edge to cut into your tires with.
i already have on 205/50/15 wheels. and have no rubbing issues whatsoever? i am on tanabe df210 springs. can this sound right?
Originally Posted by ChampionJeep
Do you already have the 205/50? You should look into a 195/45. What kind of drop do you have on the car?
