is a rear sway worth it?
Old Aug 31, 2007 | 07:39 PM
Murbyrne's Avatar
MN Scions
Default is a rear sway worth it?
The title pretty much says it all? I can get a TRD rear sway bar for $180 installed? Is it really worth it? is there that much of a difference? Thanks
Old Aug 31, 2007 | 09:09 PM
trdsparks's Avatar
The rear sway is pretty much the most noticeable improvement that you can make to almost any vehicle. The TRD one is really good, we sell that as well. 180.00 installed is an excellent price. We also have the brand new Hotckis Heavy Duty rear sway. There is a HUGE improvement on this one over the last model Hotchkis and the TRD sway. We have it on our site for $128.95 here:
http://www.trdsparks.com/displaypart...&parts_id=1685
Old Aug 31, 2007 | 09:46 PM
IH8ONYU's Avatar
yes, very worth it, unless you like body roll in turns... i have the progress tech one, and it rocks.. you want something about the size of a quarter or bigger... the install takes about 5 min if you have a jack and a socket set.. it's very easy to do yourself if you are mechanically inclined, if not let someone else get dirty and do it for you and enjoy the ride!
Old Aug 31, 2007 | 10:42 PM
burstaneurysm's Avatar
This should also be a stickied thing.
The rear sway is friggin awesome.
List of things that need to be stickied:
1. The blue temperature light
2. is a rear sway worth it?
Old Aug 31, 2007 | 10:52 PM
OldSciGuy's Avatar
just saw a post on another site (clubxb) for an h-brace group buy at $50 shipped.
Sounded good... is this as good as, or better than, a standard anti-sway bar?
Old Aug 31, 2007 | 11:01 PM
BoiseAuctioneer's Avatar
It is just as good in my opinion it really strengthens the front end in cornering!
Old Aug 31, 2007 | 11:26 PM
OldSciGuy's Avatar
Ahh... ok, I thoought the h-brace was for the rear... shows what I know.
What if you went with an h-brace AND a rear anti-sway bar?
Good, bad, weird?
Old Aug 31, 2007 | 11:38 PM
Would make for great stability!
Old Sep 1, 2007 | 02:28 AM
XbbbbBox's Avatar
Progress Tech sway buy is best buy. Definately on med to hard corning, notice a difference. Even w/my stock 15" tires. Front in my opinion does not do anything.
Can buy Progress for $140 shipped here:
http://www.ptuning.com/html/Item-Des...l&ModelDesc=xB
Cheaper than TRD - same quality - easy install.
Old Sep 1, 2007 | 03:17 AM
Front STRUT bar does nothing H-Brace does wonders for 1/3 the cost
Old Sep 1, 2007 | 10:51 AM
CBSIMONSEZ's Avatar
Last i heard, the Progress rear sway was the largets around at 22MM thick! I have one, the GF has one .. her bro has one and we all love it. Installation is a breeze with a wrech, a socket and a frined to help hold it in place.
Old Sep 1, 2007 | 02:19 PM
Sciond's Avatar
nope the new Hotchkis is 24mm
Old Sep 1, 2007 | 09:33 PM
BeQuietAndDrive's Avatar
A rear sway is a great addition to your suspension
I just picked up the new Hotchkis bar and it's a really nice peice. I love it.
Old Sep 2, 2007 | 03:50 PM
CBSIMONSEZ's Avatar
Cool, how is the install? I know with the Progress the have both nuts welded onto a plate making the install so much easier.
Old Sep 2, 2007 | 05:03 PM
JSosa's Avatar
VERY worth it!!
Old Sep 2, 2007 | 10:43 PM
mdtjr's Avatar
Any rear sway bar is worth it. Greatly improves the handling.
Old Sep 4, 2007 | 11:34 AM
bB2NER's Avatar
Music City Scions
I'm running the Whiteline bar and it still brings a smile to my face when doing a cloverleaf.
Old Sep 4, 2007 | 04:28 PM
cherry-8's Avatar
Put on a Progress Tech 10 days ago that I bought second hand. It makes a big difference.
The install is easy enough, even without the flange nuts with plates. Whoever put the bar on the first car (the seller said it was a dealer tech) mismatched fine and coarse metric bolts and nuts. I only had one flange with a plate. I used a bit of tape to hold the deeper nut and a washer to my box wrench and the job took about 1/2 hour tops. The little baby is now quite sweet on the cloverleaf.
Old Sep 4, 2007 | 10:28 PM
kehoz's Avatar
Just had the Hotchkis 24mm rear swaybar put on.
It works great, and has really reduced the body roll and tightened up the handling on corners.
Old Sep 4, 2007 | 10:32 PM
JDMJim's Avatar
i need one since my rear air bag system uses one valve. gets a little soggy sometimes.
