Scion XB Air bags
#41
chunk check out this thread:
https://www.scionlife.com/forums/viewtopic.php?t=97996
I've heard that's it's not bad at all, maybe u could PM some of the people in that thread and ask them (i wouldn't post questions in the thread because they asked for pics only no questions)
#43
#44
I'm getting ready to start piecing together a air ride system. But am curious to the dual needle gauges. Do they monitor air pressure from 2 sources or just one. Or is the second needle more like a warning needle for a bad pressure switch or something? And would the air line for the gauges be small enough to run in a pillar mount gauge pod?
#51
Originally Posted by p2filz
the xb is unibody air ride wont work from what ive heard
#52
#54
I like my air. Unfortunatly, I don't like the leaks. I still haven't been able to lock down the problem. Try to simplify your install as much as possible. That will make troublshooting easier. Equipment under the car? I am scared to do it cuz of the fact of how debris is really on a road or highway. the fear of something puchturing(spelling?) the tank, etc. I used 1/2 inch line. I feel the car drops too fast. I am wondering what I can do to slow it down a bit. Got a bodykit coming and I don't want to smash it into the ground. Use stiff aftermarket rear shocks and a sway bar in the back if the rear bags are one common line. otherwise the car handles really goofy and sloshy. I personally don't like it. That will get changed really soon.
#55
how much have u guys paid for ur air ride then?
Jim you running 2 valves in the rear? I think i'm gonna just do 4 and be done with it, tired of all the debating
#56
#57
#58
Originally Posted by magicmanjk808
#59
Spider13 is dead on. That is the quickest, cheapest, and simplest way to slow down dump valves. Just by the plug and drill it out. Start with 1/8" hole and see how it does. If it is too slow bump up the hole diameter 1/16" at a time.
