Strange Noise?
Old Jul 25, 2007 | 06:12 AM
koreanscionxa1's Avatar
Default Strange Noise?
I have a problem in my xA where if im taking right hand turns and i go over a small bump or dip that i hear a definate thumping sound coming from my front right shock tower area. Any one have any idea what could be causing this? I have tein s-techs on stock shocks and struts thats about it and stock wheels and tires. Any insight would be greatly appreciated!
Old Jul 25, 2007 | 03:05 PM
burstaneurysm's Avatar
Check the top nut... it tends to loosen up after a spring install. Pop the rubber cap off of the top of the shock tower and it's a 17mm nut. Just crank that down, it should resolve your issue.
Old Jul 25, 2007 | 03:38 PM
thank you very much, i will try that right now!
Old Jul 26, 2007 | 05:03 AM
symiansix's Avatar
if that didnt fix it i would take a good look at the strut itself. you could have blown a seal the seepage might be slow so it could not be that noticable
Old Jul 27, 2007 | 06:28 AM
i tightened down the bolt and that seems to have fixed the problem..but if it persists then i will definately look to see if i blew a seal..thanks
Old Jul 30, 2007 | 02:09 PM
BrianxB's Avatar
you didnt blow a seal. Your top hat is not aligned correctly on the strut. To fix it correctly, it needs to be disassembled.
kb1sxv
Oct 21, 2015 05:00 PM
Jus2tastee
Oct 1, 2015 08:57 PM
Klashan
Sep 24, 2015 12:39 PM
Andreas24
Sep 15, 2015 02:10 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
