Tanabe S-0C coils or springs
Hey guys
I do DD on my xb i like to do some simple mods to it. I caught between getting the spring/strut combo or the Tanabe S-0C coils. I would like it to be comfortable cuz i do drive quite awhile to work. Does anyone have pictures of their xb with S-0C coils installed?
heres the specs of the coils
http://www.tanabe-usa.com/s0c.asp?id=6
thanks for the help guys
The spring isn't the only thing you should be concernd about if you're looking for comfort. No matter what brand of spring you go with, If you're going with springs I'd recomend some good shocks too.
I understand somewhat that springs on stock shocks would wear out the shocks a lil faster but does it matter that much though? I mean if thats the case shouldn't the coilovers be a better option?
If you are eventually looking to bag it, coilovers are a good step in that direction. However, if you are looking to get a more agressive stance with a solid ride, you shouldn't have a need for coilovers really. Running springs with the stock shocks will definitely wear out fast and you will be able to feel a huge improvement on aftermarket. Also, some Energy bushings will help greatly as well.
In total, I paid a little over $650 for the df210 springs. konis, and energy bushings. The coilovers by themselves is about $900. For the same difference you can go up to bags. From what I've seen though, the ride is better on coil/springs or bags... I haven't found a decent ride with coilovers yet.
If you do go with springs, I'd recommend looking at the DF210s since they have a progressive coil rather than static.
Koni is known to be a better Shock than what most coilovers come with. So a good spring like the Tanabe and the Koni shocks would be an ideal setup. An odd thing I noticed is that after I got the Energy Bushings I noticed that not only did the xB handle better but the ride was actually better too!
Springs: tehBay
Shocks/Struts: Tirerack.com (had a 10% repeat customer coupon)
Bushings: KCTrends.com (local custom shop)
If you go the route of tanabe+koni+bushings and add a front/rear swaybar... the b will be extremely planted and it will have a fantastic ride quality about it you find in high end eurolux type cars. I've all but diminished the oversteer on my b down to zilch. When I turn the wheel, there is no sidways travel or rolling. Normal driving feels better than stock with the upgraded shocks/struts.
Springs: tehBay
carid
02-12-2015 11:54 AM
kleecker
01-09-2015 02:26 PM
bBOXD
28
12-07-2003 07:08 PM
TOY_bB
9
12-06-2003 05:15 AM
TOY_bB
11-29-2003 03:50 PM
