Tein S-techs shot after 15000 miles?
Old May 8, 2009 | 04:41 AM
Brucker3's Avatar
Default Tein S-techs shot after 15000 miles?
I did some searching but not sure that I came up with a definite answer so...
About 15000 miles ago I installed S-Tech springs and it seems like the last 3000 miles or so the quality of my ride is absolutely horrible.
I know that the xB ride has never been the best, but it is getting to the point that even when going over the slightest bump or crack in the road my passengers are complaining how rough the ride is.
From your experiences, do you think that my springs are most likely the cause of this or could it be something else?
Old May 8, 2009 | 04:53 AM
flying_toaster's Avatar
did you replace your shocks when you did the springs? if so which ones where they and where they adjustable?
Old May 8, 2009 | 05:00 AM
Domo's Avatar
could be the shocks but i doubt it, our shocks are pretty well built from factory..most likely its your springs...I say get new springs. Its only 195
Old May 8, 2009 | 05:38 AM
jetblast's Avatar
I have the Monroes w/ S-Techs, they help, but wish I would've gotten the Konis. Wheel tire setup also roughens things.
Old May 8, 2009 | 02:39 PM
Brucker3's Avatar
What would you guys think about just putting the factory springs back on? Should that help until I can get the money to throw some different springs back on?
Old May 8, 2009 | 05:07 PM
swartzautoman's Avatar
your shock will allways were out befor your srings will.
i would replace the shocks and struts first because the most likly need replaceing anyway, and "THEN" if you still hae the problem go with new spring.
i can almost promis you its your shocks and struts.
keep us posted as to what you do and what happens so others will know
Old May 8, 2009 | 05:44 PM
Brucker3's Avatar
Thanks for the good info swartz, but my car only has 25K miles, how long are the factory struts and shocks suppose to last? Thanks again
Old May 8, 2009 | 06:01 PM
365Motorwerks's Avatar
Most makers will say at 50,000 miles they should be replaced for best ride quality but that will be dependent on how and where you drive, loads carried, wheel and tire selection, ride height...etc. I agree with all the others that if they were installed correctly it sounds like struts/shocks. Btw I have never had an issue with my s-techs.
Old May 8, 2009 | 07:00 PM
bbszero's Avatar
Stock shock/struts life expectancy is shortened when lowering springs are intalled. Your S-techs are not worn out,
Old May 8, 2009 | 09:20 PM
X2
Old May 9, 2009 | 10:49 PM
ChampionJeep's Avatar
x3 Tein is a quality spring. I can't believe they went bad. Change shocks and struts and you will be fine.
Old May 11, 2009 | 08:55 PM
Brucker3's Avatar
I'm gonna get it all checked out on friday so i will keep you all updated. Thanks for the help
Old May 11, 2009 | 09:01 PM
yes, keep us posted
Old May 11, 2009 | 09:35 PM
burstaneurysm's Avatar
200% sure that you just blew your shocks/struts.
Old May 11, 2009 | 11:15 PM
Sciond's Avatar
yeah I am with Ian basd on the amount of travel your stockers are made for...
Old May 17, 2009 | 03:26 AM
firesquare's Avatar
my s-techs have well over 60K on them. they have gotten very soft lately. but i should change my struts out. they're still factory
Old May 17, 2009 | 11:26 PM
JSosa's Avatar
x4. My S-techs are going on 50K now
Old May 18, 2009 | 12:12 AM
--Final_Wrath--'s Avatar
bro, its your shocks/struts.....springs RARELY go bad...trust...I work as a Mechanic, just replace your shocks and struts
Old May 24, 2009 | 04:14 AM
bB384's Avatar
IV ACE
I'm not saying the OEM shocks are any good, because they are crap. But S-Tech's aren't any good either. I bought them and used them for 100K and I regret ever getting them, the only reason why they're still on my car is because im too lazy to swap back to the OEM springs, and I'm still researching my options on a good coilover set up.
Old May 24, 2009 | 04:38 AM
Originally Posted by bB384
But S-Tech's aren't any good either. .
what was your bad encounter.
the only problem ive with tein spring is the back ones tend to be a bit soft.
180 pound springs are too soft it realy need to be more like between 215 and 240.
i had the s-techs then when to ss coilovers and ended up using a custom 220 spring in the rear.
i understand why they do that, i just didn't work for what i wanted to do
other then that, Tein is high quality stuff
