TRACTION CONTROL /VSC LIGHT AND ENGINE LIGHT ON
Old Mar 12, 2007 | 02:39 AM
skimbob2's Avatar
Default TRACTION CONTROL /VSC LIGHT AND ENGINE LIGHT ON
I NEED HELP !!!!! WHILE INSTALING MY COLD AIR INTAKE.. SOME HOW WHEN I FINNISHED MY TRACTION CONTROL /VSC AND ENGINE LIGHT ALL CAME ON AND MY XB WONT GO PAST 3000RPM ITS BOGGING DOWN ... HOW DO I FIX THIS .. I CANT DRIVE SO I NEED HELP FAST..
THANX
Old Mar 12, 2007 | 02:40 AM
burstaneurysm's Avatar
Did you reset the ECU?
Also, turn off the caps, no need to yell.
Old Mar 12, 2007 | 02:46 AM
WagenMaster's Avatar
You messed up your MAF sensor somehow.
Same thing happened to my friend after he installed his CAI and washed his engine down with a hose. I drove over and put my MAF in and it was fine. He had to go to the dealership and buy a new one...
Old Mar 12, 2007 | 02:51 AM
kevinjr03's Avatar
Try the ECU reset first, if the lights come back your MAF is likely messed up
Old Mar 12, 2007 | 03:50 AM
TJ's Avatar
TJ
I had that occur after i reinstalled my AEM intake a while back. I reset the ecu ... the CEL came back up. I then proceeded to clean the little sensor thingy on the MAF with a little rubbing alcohol on a few qtips ... reinstalled it and its been working fine ever since.
That trick may or may not work.
Old Mar 12, 2007 | 06:23 AM
OldYeller's Avatar
Please try a search--this subject has been covered over and over again. Make sure all the connections are tight and try to clean the MAF sensor. If you have to replace it you will have to shell out a few bucks. Good luck.
evolving_machine
Oct 21, 2023 01:16 PM
12xb
Nov 7, 2015 03:44 PM
daniinpitt
Apr 4, 2015 08:07 PM
toyotaisme
Jan 10, 2015 10:24 PM
TheRedBox
Oct 8, 2003 04:25 PM
