TRD sway bar installed on RS 1.0 - Wow!
Old Jul 3, 2006 | 08:16 PM
bB2NER's Avatar
Music City Scions
Default Re: TRD sway bar installed on RS 1.0 - Wow!
Originally Posted by Epitrochoid
Originally Posted by ".[/quote
Cool Thanks I moved this item up to the top of my must haves list. How much did you pay shipped for the TRD. I'm torn between that and the Progress one.
$145 plus shipping and Ken a Sparks shipped it the same day. Call him for a shipping quote.
Thanks, I'll check them out!
Old Jul 3, 2006 | 08:24 PM
illiST's Avatar
Closed for holiday.. I tried ordering one as well.
Old Jul 21, 2006 | 08:34 PM
N-Dawg's Avatar
I just finished ordering a rear sway bar & in the description it says 69% increase in the outer hole ( raceDrving) & 39% in the outer hole (street driving). What does this mean? I'm assuming you can't install in the inner hole for daily driving. Is this correct? Any help is greatly appreciated.
Old Jul 21, 2006 | 08:36 PM
N-Dawg's Avatar
I meant to say "39% stiffer in the “street“ setting (outer hole), and 64% stiffer in the “race“ setting (inner hole)"
Thanks for any help.
Old Jul 21, 2006 | 08:43 PM
illiST's Avatar
It means it's stiffer when using the inner hole.
By using the inner hole, the bar increases it's rigidity. IE: giving you more over-steer. This is considered a "race" setting (not sure why, as it's misleading).
It's just two levels of stiffness. Street and Race. Where Race is giving you a stiffer setting. (more over-steer characteristics.
Old Jul 21, 2006 | 08:48 PM
N-Dawg's Avatar
Thanks. Which setting do you recommend?
Old Jul 21, 2006 | 10:08 PM
illiST's Avatar
It's a personal preference. You may not like the race setting. Or you may want more oversteer than the street setting offers.
Try them and see what you like better.
Otherwise, I'm not sure the TRD Sway Bar is adjustable. (the topic of the thread)
Old Jul 21, 2006 | 11:15 PM
revjolly1's Avatar
can someone do a DIY? i have my sway bar sitting in my back seat because i dont know how to install it. i have an 06 xA if that helps
Old Jul 22, 2006 | 12:19 AM
Epitrochoid's Avatar
It's really EZ to do. It literally justs bolts right up to the torsion bar.
Old Jul 22, 2006 | 05:33 AM
bB2NER's Avatar
Music City Scions
The TRD and Progress are real easy compared to the Whiteline one.
Old Jul 22, 2006 | 09:31 AM
revjolly1's Avatar
i have no idea what s torsion bar is. can someone plese help me?
Old Jul 22, 2006 | 02:06 PM
SkyonXa's Avatar
What kind are you getting that's adjustable?
Old Jul 22, 2006 | 03:59 PM
illiST's Avatar
http://auto.howstuffworks.com/question432.htm
Old Jul 23, 2006 | 06:18 AM
bB2NER's Avatar
Music City Scions
The TRD is adjustable if you can call it that. There are 2 bolt holes depending on how stiff you want it. Track or Street.
Old Jul 23, 2006 | 01:43 PM
illiST's Avatar
Are you sure the TRD bar is adjustable? It does have two holes, but the installation instructions don't state anything about it being for stiffness adjustment.
You must use both (two) holes on each side of the bar (4 hbolts total) to properly install. This is the reason I don't think it's adjustable. As you must use all four holes/bolts.
With an adjustable bar, you must select one OR the other hole. Not both.
Old Jul 23, 2006 | 01:51 PM
Actually I just jacked up my xA to check this out. There is only one way to install the sway bar. That was what I thought when I first put the bar on my car but all this talk prompted me to check it out. I believe the xB has the option for two settings but the xA (at least mine) does not.
Old Jul 23, 2006 | 01:56 PM
illiST's Avatar
ah, thank you!
Old Jul 23, 2006 | 03:20 PM
bB2NER's Avatar
Music City Scions
My bad. I must have gotten bad info on there being more than 1 set of holes. Unless I know for sure I'm not passing on bad info. anymore. Sorry
Old Jul 23, 2006 | 03:58 PM
There are 3 holes on each side but there is only one way to line up the bolt pattern.
Old Jul 23, 2006 | 04:13 PM
bB2NER's Avatar
Music City Scions
That must be so it will fit multiple applications.
