UNIBODY XB w/ AIR SuSpEnSiSoN
Old Jun 19, 2006 | 07:41 AM
27300man's Avatar
Default UNIBODY XB w/ AIR SuSpEnSiSoN
Do you guys think hitting switches Front, Back, Side, to Side (FBSS) w/ 3/8 valves and 1/2 line will affect the XB's unibody frame?
I'll put up some pics soon!!
Old Jun 19, 2006 | 07:44 AM
blackwagon's Avatar
nah i do it, no ill effects as of yet. i never leave the xb parked leaning on one side tho. keep dragging!!!!
Old Jun 19, 2006 | 11:13 PM
RTon20s's Avatar
You aren't likely to see problems as long as you don't abuse your new suspension. Over time it very well could problems if you aren't careful. Also, make sure you aren't running high pressure. Anything over 175 psi on the xB is way too much.
Considering the weight of the xB, running eight 3/8" valves with 1/2" line is equivalent to running 1/2" valves with 5/8" or even 3/4" line on a fullsize truck.
Old Jun 19, 2006 | 11:50 PM
blackwagon's Avatar
brace the frame... should help a little but will most likely change your handling charicteristics. i havent yet but i plan to.
Old Jun 21, 2006 | 08:20 PM
RTon20s's Avatar
FYI... No frame to brace. Hence the unibody. There are subframe / chassis braces you can buy though that could help.
Even with all of the bracing in the world, I still wouldn't recommend "extreme" use of an air suspension on an xB.
Old Jun 22, 2006 | 10:46 PM
blackwagon's Avatar
yes i know exuse what i said... i am so used to mini tucks its like automatic
Airbagged
Scion iQ Suspension & Handling
Oct 30, 2014 11:49 AM
jamesfg49
Regional - Desert & Salt
25
Feb 7, 2009 08:21 PM
Bigfieroman
29
Sep 16, 2007 07:51 AM
Az_Scion_tC
Scion tC 1G Aero & Exterior
66
Jun 27, 2006 04:00 AM
BrianxB
Jan 23, 2005 04:02 PM
