Will i need Shims?
Old May 4, 2006 | 04:05 PM
BloodySunday's Avatar
Default Will i need Shims?
I'm buying some 16" x 7" Rota Circuit 8's.
Apparently they come with Falken Ziex 512 rubber : 205/50/16
I have some goldline springs on the way as well. thats about a 2" drop, right?
anyway, will i need shims or anything else?
and are these tires good?
TIA guys
Old May 4, 2006 | 08:50 PM
anyone?
Old May 4, 2006 | 08:56 PM
Storm13's Avatar
I'm no expert on this, but I think whoever is able to help you will need the offset of your wheels in order to make an educated guess.
As for the tires, I'm running the same model in 17's and I like them.
hayalex6's Avatar
what's the offset?
Old May 4, 2006 | 10:27 PM
bBoxed_In's Avatar
since it's a ROTA and since it's only a 7" wide rim i'm going to assume the offset is a FWD setup (high offset) so yes, you could get shims if you prefer. you probably don't NEED them but it'd probably help for aesthetic reasons.
depending on how far you wanted to space out the rear wheels will depend on which one you should get (10mm, 15mm, 25mm or other).
Old May 5, 2006 | 08:12 AM
40mm offset
Old May 5, 2006 | 08:13 AM
it's 40 mm offset. and what kind of aesthetic properties will the spacers provide?
i don't even know what they are for
Old May 5, 2006 | 11:44 AM
Storm13's Avatar
I'm no expert on the fitment issue, so I'll let somebody else handle that question.
As for what a shim or spacer does, it moves your wheels & tires more toward the outside "edge" of your fender so the wheels/tires sit more flush with the edge of your fenders.
Old May 5, 2006 | 12:08 PM
mill0048's Avatar
I'm running Rota Track-R's with those same dimensions. I had 25mm spacers and the wheels rubbed the fenders. I know someone who has the sames size as us and he's using a 15mm spacer without rubbing issues. Eventually, I'll get 15mm spacers for the rear. As it stands, it looks like the wheel is recesseed too far into the wheel well. The spacers will bring the wheel closer to the edge of the fenders as Storm13 said. There could be a performance increase in handling, but probably not noticeable. It's pretty much asthetics as mentioned above.
Old May 5, 2006 | 02:43 PM
where is the best place to get some Shims? and how hard is it to install?
Old May 5, 2006 | 03:07 PM
asnd does anyone have pictures of an xB with and without spacers?
is the difference really night and day?
Old May 5, 2006 | 04:02 PM
hayalex6's Avatar
Check out the OneTonGarage website. there are some before-after pics.
Old May 5, 2006 | 05:01 PM
i can't really tell a difference : /
Old May 5, 2006 | 08:27 PM
jomo's Avatar
Could also be a handling decrease. Although the track is increased which can benefit cornering, the rear spacers will increase understeer which is not desireable. The end result is likely a push.
A stiff rear sway will correct any harm the rear spacers did (if any). The rear sway is a must anyhow for one who care about handling.
Old May 5, 2006 | 09:52 PM
mill0048's Avatar
BloodySunday:
In all reality, if you can't tell the difference appearance wise, you probably shouldn't get them. It is sublte. Save the money for some other upgrade.
jomo:
Not to go off topic, but breifly, is the rear sway "that" noticeable? I was thinking of getting one, but I heard it's not that great. Also, what brand?
Old May 5, 2006 | 11:30 PM
jomo's Avatar
Who said that? The simple/cheap way to more neutral handling with this car is a rear sway. Progressive, Whiteline, or the TRD should work well (all 22 mm). The 12.4 mm Hotchkis will not do much by itself. I have the feeling that it needs to be paired with the hollow front sway for best effectiveness.
rancur3p1c
Jul 12, 2015 07:59 PM
scionhawaii
13
Jun 19, 2015 03:59 PM
kleecker
Jan 2, 2015 08:09 PM
Silencei2
15
Feb 4, 2006 06:03 AM
Epitrochoid
9
Dec 21, 2004 04:30 PM
