xB Rear Brake Line disaster
Old Feb 19, 2012 | 11:33 PM
dods2403's Avatar
Angry xB Rear Brake Line disaster
Alright, going to try and keep this simple. Car has 160k miles on it and the rear left hub/bearing finally took a crap on me so I replaced it. As you can imagine, the hub was rusted in the bracket pretty good so it took a BFslidehammer and alot of banging to get it out. Little did I know the back of the drum was also rusted on the hub so when the hub finally decided to break loose, the back of the drum went with it.
Well, as luck may have it, his pulled the hardline to the brakes (the one that goes from the softline to the back of the drum) and due to the rust on this line, it decided to break in half at the nut.
Well, now im stuck. I went to the auto parts store to get a brake line and bend it myself. Well turns out this brake line has two different flarings/fittings from one end to the other so the auto parts store doesn't carry it.
I believe the only options I have are to go to the dealership and see if I can get this part or get one made from inlinetube.com (which happens to be only miles away from my house).
Do you guys think the dealership could order this line pre-bent and ready to go?
I cant be the only one who has ever had to ruin this line???? Anybody have any help out there?
Thanks again,
Dods
Last edited by MR_LUV; May 6, 2018 at 06:17 PM. Reason: Moved to Correct Forum by Moderator
Old Feb 19, 2012 | 11:36 PM
dods2403's Avatar
The line im referring to is the one in this picture going into the backplate of the drum (thanks to whosever picture this is)
Old Feb 20, 2012 | 01:24 AM
sdsnybny's Avatar
Passenger side tube part #47323‑52090
driver side tube part #47324‑52080
Looks like they are $10-15 each
Join here for a good part # micro-fiche source http://www.toyodiy.com/
Old Nov 9, 2023 | 10:08 PM
typhoonorchid's Avatar
I discovered I need this same part that runs from the hose to the wheel cylinder. It just sprung a leak from rusting out. Big puddle of brake fluid around my rear wheel. Only $22 from the dealer. I thought that was reasonable.
I cut the line on the old one just so I could get a 10mm socket, and an impact, on the fitting going to the hose. My flare nut wrench wasn't doing it.
Old Sep 27, 2024 | 11:12 PM
joeq's Avatar
And no response, or conclusion from the OP. Typical.
Old Oct 4, 2024 | 12:47 AM
2stroked's Avatar
The original post was from 2012, The OP is probably dead by now.
Old Oct 4, 2024 | 11:27 PM
joeq's Avatar
I did see that. I came here for his story, to maybe gain some incite to my problem, but of course, another dead end from some-one looking for a quick fix for them, with no concern for any other members. Everyone knows it happens more offen than not, and not just here.
Old Oct 5, 2024 | 05:23 PM
MileHightC's Avatar
Super Moderator
SuperMod
What response did you need...you've been given the Toyota part numbers and a parts diagram and the lines are available from Toyota, so you could get them from your local dealer or an online OEM parts vendor. I wouldn't mess with getting lines made as they'll likely be more expensive and fitment wouldn't be guaranteed.
Take your pick...
Old Oct 6, 2024 | 07:05 PM
joeq's Avatar
In my other thread, (that you replied to), is the XB rr disc brake issue, I'm in the middle of. I've been checking your site for information, and tried this thread out, W/O much help. Maybe thought there would be some info on brake bleeding.
bcp06tc
May 14, 2013 11:02 PM
x_Batman_x
27
Oct 2, 2012 05:57 PM
dgenem
18
Apr 20, 2012 04:47 AM
gp1817
Jan 18, 2011 01:29 PM
raamaudio
Scion tC 1G Wheel & Tire
15
Nov 29, 2010 07:20 PM
