+45 Offset??
Old Mar 17, 2005 | 03:02 AM
HammerHead's Avatar
Default +45 Offset??
I'm looking at a set of rims and tires and want to know if anyone sees a problem with this package? A couple of people have said that you don't want to go bigger than a +42????
Rims are 18" X 7.5"
Tires are 215/35/18
Any comments would be appreciated on the fitment of this setup for my xB. Thanks...............Don
Old Mar 17, 2005 | 06:18 AM
maxsin's Avatar
I am at 42mm offset and it is really close to the rear frame. I cannot fit my pinky finger between the tire/rim and rear car frame. A member pointed me to this site for a rear 10mm fix...
http://www.onetongarage.com/
My setup, Nakayama 6-speed 17in rims 42mm offset with 215/45/17 Yoko tires.
Old Mar 17, 2005 | 07:38 AM
PandaIst's Avatar
One ton garage makes excellent products. I love the rear spacer shims.
Old Mar 17, 2005 | 01:44 PM
ikhonlord's Avatar
You will definetely need spacers in the back if you dont want the inside of your rim to touch the rear frame. There is a bolt in the rear frame that will scratch your rim ( I know this because it happened to me)
Old Mar 18, 2005 | 10:20 AM
TREX212426's Avatar
is there anything wrong with an 40 off set? will it cause a problem with handeling i.e. 17'' rims with some 205/40/17 tires will this impose a problem?
Old Mar 18, 2005 | 12:11 PM
katchkillah's Avatar
hehehe or just break the bank and get a +30 offset.
Old Mar 18, 2005 | 04:52 PM
ugly_duck's Avatar
40 will work fine, Go with a 215/40 instead.
You will probally want rear shims to pull them out a bit to get a wider stance and look.
Old Mar 18, 2005 | 05:03 PM
TREX212426's Avatar
how much will the shims cost?
Old Mar 18, 2005 | 05:43 PM
boxanne's Avatar
I have the exact setup you're talking about. That's a 45mm offset rim on a 215/35/18. Just some spacers in the rear and you're set.[/img]
Old Mar 18, 2005 | 06:18 PM
TheScionicMan's Avatar
The rear spacer shims at www.onetongarage.com are $65 including shipping. A great product, easy to install and doesn't mess with your wheel studs like regular wheel spacers.
http://www.onetongarage.com/products...him/index.html
Old Mar 19, 2005 | 12:39 PM
WRxB's Avatar
Defined3
I have 18" X 7.5 with a 45mm offset & the One Ton 10mm Shims & 5mm Spacers front & back. 215/35/18
I would show you a pic but I am not installing all of this until next weekend. I'll do it sooner if I get a fire under my _ _ _ !
Old Mar 19, 2005 | 02:02 PM
TOAST3R's Avatar
i had 18x7.5 with a 45mm offset and 215/40/18 tires on trd springs and trd struts and shocks. i never had any rubbing issues
Old Mar 21, 2005 | 01:53 AM
ugly_duck's Avatar
unfortunately in the wheel industry there are not the best standards, so if one brands "45" offset will work adn why others wont. Spacers will work and they are cheap. Good luck
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
