45 offset on the front???
Old Apr 15, 2005 | 07:09 PM
BEAT-BOX's Avatar
Default 45 offset on the front???
I am looking at a wheel that only comes in 45 & 38 offsets. I know the 38 offset is good for the rear but how will the 45 on the front do? These will be 18 x7.5 with 215/35/18. If the 45 up front is no good will a 3mm spacer do the trick? Need input ASAP. Thanks
Old Apr 15, 2005 | 07:25 PM
BEAT-BOX's Avatar
Just spoke to the wheel guys and they no longer have 45 offset so will a 38 offset work on the front? Thanks
Old Apr 15, 2005 | 07:57 PM
boostedscion's Avatar
get some pics up when you get ur rims thanks
Old Apr 15, 2005 | 08:12 PM
EMU's Avatar
EMU
if this is for a xB.....+38 will be good all around. to be flush the xB is best with a +35 front and +25 rear
Old Apr 18, 2005 | 11:50 AM
BEAT-BOX's Avatar
So I wont be sticking out in the front? Ishouldnt have any rubbing issues right?
18x7.5 +38 with35 series tires.
Old Apr 18, 2005 | 05:08 PM
JDMxB's Avatar
+38 is fine up front as well as in the rear--you shouldn't need any spacers at all to fit them.
And no, they won't stick out past the fender.
Old Apr 18, 2005 | 06:34 PM
BEAT-BOX's Avatar
Cool
I just dont want to have to worry about rubbing issues with this being my daily driver.
Old Apr 20, 2005 | 05:13 AM
JDMxB's Avatar
Unless you go down about 3-3.5 inches in the front you don't have to worry about it. Or you get some really high profile tires. Or both.
Old Apr 20, 2005 | 11:56 AM
BEAT-BOX's Avatar
What do you guys think is the biggest profile I can go with if I lower it about 2"?
Old Apr 20, 2005 | 05:20 PM
JDMxB's Avatar
I've heard that 40's rub with lock to lock steering, so I'd just stick with 35s.
Old Apr 20, 2005 | 05:26 PM
boxanne's Avatar
I've got the 35 series tire and the 45mm offset and haven't had one rub. You should be fine with the 38mm.
Old Apr 20, 2005 | 07:56 PM
BEAT-BOX's Avatar
Thanks but do we know the tallest tire we can run?
Old May 7, 2005 | 01:17 AM
04whtbox's Avatar
T he 35 series tires suck if u drive alot . With the bumps on the roads and highways . I have 40 's on my wrx and she rides sweet. But 35's on my xb and the ride is totally diffrent. There exactly the same set of tires . i put on about 100miles a day
scionlife
371
Jun 2, 2015 11:00 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
2010tc805
Scion tC 1G Wheel & Tire
Dec 12, 2014 06:47 PM
smilygo
Nov 1, 2003 11:26 PM
smilygo
Oct 5, 2003 09:51 AM
