anyone running 215/40 on 18"?
Ok so I bought some rims last week 18"x7.5 offset 42. I was planning on putting some 215/35 tires on them. So I was at the local dealership the other day and I saw in their showroom an xb with 18" with 215/40 tires. Does anyone out there have this size? Cause I was thinking with a little bit more meat it might be a softer ride.
thanks
scion619
thanks
scion619
Originally Posted by scion619
so 40 series should fit right? Just wondering if there is going to be any rubbing issues?
I ran the df210 springs thats like a 2.5 drop and the same tire size with no problems
the ride is nice. my offset is much lower than yours so i have a tiny bit of rubbing. +42 should be fine on a 7.5 wheel for 215/40s. IMO 215/35 is too thin. On my next set of tires, I might try 205/40/18s to avoid the rub and git some stretch.
Originally Posted by THE DON
I'm running 225/40/18 and it still fits
35's looks too skinny to me... 215/40/18 should be fine
-THE DON
-THE DON
hey the don what wheels are you running and what offset? Any pics
-Ryan
i am running 18 x 8" with 215/40/18"s ,lowered almost 2"s. only problem i have is that the tire rubes just a little on the lower inner raised part of the fender well in front.and thats only when i turn the wheel almost full radius. very minor issue. overall i'm happy with the ride. you can see the differance from my lava and my thunder cloud.
a 40 series 215 is about 1" in total diameter bigger than a 35 series 205
the rolling diameter of the 215/40-18 is 24.771"
the rolling diameter of the 205/35-18 is 23.649"
I covered the formulas for this last July at https://www.scionlife.com/forums/vie...ameter+formula if you need to review it shopping for tires.
I am rolling on Falken Ziex ZE-512 tires in size 215/40zr/18 (thanks to toast3r). The wheels are 18x7.5". It rides pretty good and fills in the gap slightly more than 215/35s. My ride is dropped on Tanabe DF-210s.
Ok looks as though Im going for 215/40 tires!!! Does anyone recommend a particular brand? Im on a tight budget but don't want anything cheap or to expensive...
thanks
scion619
thanks
scion619
a 215 40 will set off the speedo by 2.3% too slow meaning when your speedo reads 60 you will be going 61.4.
I got it here
http://www.miata.net/garage/tirecalc.html
I got it here
Originally Posted by kgzero
Won't 40s throw of your speedo. I have 215/35's on my xA, and was told by the tire guys not to go with the 40's cuz they will rub and throw off the spedo.
