BSP bB w/ Rosegold Axis Racer Xs
ya, the flares should be here fri., i will be sure to post pics. I hope the front flares are wide and big enough to cover the fronts! LOL What would everyone think of the -3 rear OTGs??
you're right firesquare...I got the bbist and the gelcoat had air holes in it, i didn't like them too well and the front did still stick out a bit.I think I'm going to run the 15x7 up front and negative camber the rear, go with the staggered look.should i run the same tire size on the front as the rear, as the rear wheel is an inch wider?
if your going to go staggered. running 15X7 up front and 15X8 or 15X9 in the rear. you want to match the tire to that wheel.
so im guessing with a 185/50R15 in front (just guessing) you may want to run maybe a 195/45R15 (if their is such a tire)
keep in mind with abs and TC, you have to try and keep teh wheels turning at the same speed or you'll throw a DSC code or something.
ninjastance
15
Apr 24, 2007 03:34 AM
Heymikeyyyy
44
Apr 3, 2007 03:16 AM
zatozim
Feb 10, 2007 04:36 AM
