Converting
Old Apr 29, 2004 | 02:29 PM
xbsilver's Avatar
sIcKsCiOnS
Default Converting
Does anyone know if i could convert my xb to a five lug bolt pattern? If so what would it take? I would greatly appretiate any info Thanks
Old Apr 29, 2004 | 02:32 PM
OKIHost's Avatar
I know in Mini Truckin/Truckin I see the adapters on there to convert from 4-5 lug so you may want to pick up a copy and check it out.
If you can't find it PM me and I will dig out an old copy at the office and get you the www for it.
Old Apr 29, 2004 | 02:48 PM
The_Bilingual_Gringo's Avatar
Is there a way to do it using certain Toyota parts, like hubs, etc?
Old Apr 29, 2004 | 02:50 PM
DJ_SpaRky's Avatar
The bad thing about those are that they are adaptors, they bolt on to the stock hubs then you bolt the wheels to them.
You'd be better off doing a hub & spindle swap from a FWD 5lug car, ie Accord or Camry.
The guys from HighOnScion.com did one, talk to them.
:twisted:
Old Apr 29, 2004 | 02:56 PM
:twisted:
So, heh, could the hubs and all that say from a Celica GTS be used and then you could even maybe carry over some calipers and rotors as well. [/reach]
Old Apr 29, 2004 | 03:03 PM
xbsilver's Avatar
sIcKsCiOnS
Thank you guys for you input!!!
Old Apr 29, 2004 | 05:44 PM
dinkjs's Avatar
Why would you want to? Whats wrong with just having a 4 lug pattern...5 lug wont do anything for you
Old Apr 29, 2004 | 05:47 PM
JDMxB's Avatar
Some wheels are only available in 5 lug bolt patterns..which is probably why he wants to do it--but you are correct, aside from that the only other value is aesthetic.
Old Apr 29, 2004 | 05:50 PM
EL_PAALO's Avatar
There are theoretical strength issues, but an xb is unlikely to need anything more than 4 lugs. Maybe if you take it rock crawling or slam into curbs. You'd bend something else anyway.
Old Apr 29, 2004 | 06:08 PM
dinkjs's Avatar
maybe he wants though whole "jdm" look...I am being sarcastic here...
Old May 1, 2004 | 12:35 AM
dub_box's Avatar
Default Re: Converting
2003-2004 Corolla S model should bolt up clean without and mods. It is 5 on 100mm. It can't be the standard Corolla as it is the same as the XB.
prescottn
Oct 8, 2015 05:31 PM
mischman
Sep 15, 2015 03:38 PM
crimson10tC
Sep 10, 2015 08:44 PM
ScionLife Editor
Sep 8, 2015 07:10 PM
gqdabien
Jul 30, 2015 07:04 PM
