DASHBOARD looks like a XMAS TREE - ABS sensor plug & OTG
Old Apr 12, 2007 | 02:45 AM
dmpsk8's Avatar
Default DASHBOARD looks like a XMAS TREE - ABS sensor plug & OTG
Before I get busted, yes i searched and this is a diff question than the other threads on these VSC TRAC lights
so i put on my new rims and OTG spacers today ( pics tomorrow). no big problem , tho the rear driver side took awhile to get situated. I ended up gettin really sick when i was almost done. I barfed, choked, and struggled thru the last wheel. When i started up the car and took it for a test drive i forgot to pulg in one of the rear ABS sensor plugs, thus the dash about exploded with lights: VSC Trac BRAKE ABS. Once i pulled back into the garage i reached around the back of the wheel and managed to plug the harness back in, but the lights didnt go out. Should reseting the ECU clear this? Anything else that could turn on the lights?
Old Apr 12, 2007 | 02:48 AM
bbscionxb's Avatar
yea, it should work no wire or anything got damage when you took it out for test drive what i mean is the wire that got unplung did not get damage??
Old Apr 12, 2007 | 02:51 AM
dmpsk8's Avatar
well thats what im worried about. it seemed fine and the harness wasnt cracked so i dunno. i was down by the spring so it may have got pinched. it still snapped back into place and everything tho
Old Apr 12, 2007 | 02:53 AM
bbscionxb's Avatar
well you should reset the ecu and if it works your save if not get it fixed right away
Old Apr 12, 2007 | 03:53 AM
Bill_eriksen's Avatar
Thst type of trouble code is hard coded in the ecu. It needs to be reset through diagnostics.
Old Apr 12, 2007 | 09:40 AM
dmpsk8's Avatar
so take it in to the shop and have it reset??
Old Apr 12, 2007 | 12:45 PM
hip_2b_sqr's Avatar
Double check your ebrake connection snd see if a wire was pulled out. what you described is exactly what happens when the ebrake sensor is not plugged in. All your idiot lights should go back off when you plug the ebrake connection back in and turn your car off and then back on.
Old Apr 12, 2007 | 04:20 PM
dmpsk8's Avatar
after a bit of drivin and using the brakes the lights all went out. guess it just took awhile for the computer to read the signal. Thank god
bostondaniel
Scion xD Suspension & Handling
15
Sep 12, 2020 03:16 PM
pensfan76
Jul 19, 2016 11:05 AM
streetracerr
Jul 11, 2015 09:52 PM
DAHOZZMAN
Dec 16, 2014 06:48 AM
pro710
Nov 26, 2014 12:01 AM
