Gas Milage with New size wheel
Old Jan 22, 2004 | 11:08 PM
Sgt_Scion's Avatar
Default Gas Milage with New size wheel
I am getting a little worse gas milage with my new wheels. Is this cause they are recording less milage or is it something else.
Old Jan 22, 2004 | 11:31 PM
scionracerxb's Avatar
yeah...your wheels are probably bigger i'm assuming, and with bigger wheels, they rotate less times to go the same distance as a smaller wheel, thus recording less miles on your odometer
Old Jan 22, 2004 | 11:32 PM
heres the link to the tire size calculator...it is preeeety cool and will tell u 4 sure whats up.
http://www.saturnperformance.com/tech/tiresize/
Old Jan 22, 2004 | 11:51 PM
fortyninerhater's Avatar
Hey there. Keep in mind also, that if you are running wider tires than stock you will get less mieage too because of more road contact. My 2 cents.
-E
Old Jan 23, 2004 | 12:41 AM
doctorcue's Avatar
Dude...sup with the name? Especially living in South SF...man, guess we won't be seeing you at the `Stick on Sundays...
Old Jan 23, 2004 | 01:12 AM
Heh... I was waiting to hear something about my screen name. lol I've always been a Raiders fan. :twisted: Hopefully there will be something to cheer about next season.
-E
Old Jan 23, 2004 | 03:33 AM
rbloedow's Avatar
Which would mean that he would be getting better gas mileage, which isn't the case.
Old Jan 23, 2004 | 03:36 AM
Sgt_Scion's Avatar
no i think that it would be the case i check my gas milage by milage recorded divided by gallons put in
Old Jan 23, 2004 | 03:45 AM
rbloedow's Avatar
I was just pointing out the false logic. Keep checking the mileage, anfter 5 more fillups take the average of the 6 and see what it's like.
Old Jan 23, 2004 | 01:59 PM
jackmott's Avatar
Guys, normally the tires you get with your bigger wheels have a shorter sidewall, so the overall outer circumference of the TIRE is the same. So there shouldn't be any major change in your odometry.
do a search on google for "miata tire calc" it has a little web program that lets you compare tire sizes to see how far off your speedo will be.
The reason for the mileage drop probably has to do with the wheel/tire combo being heavier. Wheel weight has a major effect on acceleration and in turn mileage as well, due to rotational intertia. Wider tires, as mentioned earlier, will also offer more rolling resistance.
you can try running higher tire pressures to offset this somewhat.
Old Jan 23, 2004 | 03:43 PM
yanges's Avatar
if you are running 215/40/17 as indicated in your profile, then there is minimal difference and it would not affect gas mileage calculations much....
those are just slightly larger than stock tire/wheel combo....
what pressure are your tires set at? that could affect mileage....
i have the same size tire/wheels as you and i keep my pressure at 34psi.....
it rides well at that pressure and i am getting 27-29mph city driving....
Old Jan 23, 2004 | 05:25 PM
HemanC's Avatar
Is there any rule of thumb as to what psi to put in to difference size?
Old Jan 24, 2004 | 12:16 AM
Sgt_Scion's Avatar
not quite sure what they are at right now. But I was getting about 29 miles now im getting round 27
Old Jan 24, 2004 | 01:44 AM
yanges's Avatar
how many miles are on your xB?
Old Jan 24, 2004 | 02:25 AM
Sgt_Scion's Avatar
just over 14000
Old Jan 24, 2004 | 02:39 AM
bBted's Avatar
only a hair difference on gas mileage...
Old Jan 24, 2004 | 02:40 AM
Sgt_Scion's Avatar
yeah but that is noticable when you drive over 100-200 miles a day
Old Jan 24, 2004 | 07:29 AM
jackmott's Avatar
so put some lighter wheels and thinner tires back on
youll accelerate quicker too.
Old Jan 24, 2004 | 08:03 AM
UrbanDrum's Avatar
Would getting 18's or 19's make it much worse than stock? :?
Old Jan 24, 2004 | 02:42 PM
jackmott's Avatar
any heavy wheel could
18s/19s tend to be heavy
rain7905643
Mar 14, 2015 12:48 AM
dzcustom
Nov 6, 2003 12:54 AM
BradinVA
Oct 3, 2003 12:50 AM
scionlife
Apr 16, 2003 05:13 PM
