Hubcentric ring question
Old Dec 12, 2006 | 12:53 AM
octagon's Avatar
Default Hubcentric ring question
I have 4 5zigens and jut bought two more, four of the have metal hubcentic rings in them that i bought from somewhere i cant remember. (Which is the problem!) If i ran 2 plastic hubcentric rings in the new wheels will i have a problem?
Old Dec 12, 2006 | 01:57 AM
RTon20s's Avatar
Shouldn't be a problem at all. In fact, I have never run hubcentric rings at all. Never had a problem either. Proper installation and a good balance have always worked for me.
Old Dec 12, 2006 | 08:27 PM
octagon's Avatar
Tank you
Old Dec 16, 2006 | 08:08 PM
bB2NER's Avatar
Music City Scions
Metal or plastic they do the same thing. I always use them just to make sure the wheels run true. Plus it takes some of the load off the lugs and places it on the hub center as intended.
Old Jan 12, 2007 | 05:27 AM
xb27's Avatar
Actually, plastic Rings are better than Aluminum because they don't corrode when they get wet...quite often Aluminum will fuse to the wheel and make it very difficult to remove them...so if you have a choice, deffinately go for Plastic Hubcentric Rings.
Old Jan 28, 2007 | 02:17 AM
Doulish's Avatar
Default Silly Newbie Question
I've barely had my xA long enough to poke around on it...so, are the EP-10's Hubcentric?
Or do I only have to worry about getting rings when I buy different rims?
Old Jan 28, 2007 | 02:51 AM
06B0X's Avatar
Default Re: Silly Newbie Question
That depends on what wheel you purchase???? The wheels I have cause a vibration at high speeds so I purchased plastic rings off ebay for $14 shipped. The OEM ring is 53mm, my wheels are 73mm (I think) so I have 20mm of "space" between my wheel and the hub.
I intend on getting them installed during my next oil change/balance/rotate at the stealership and taking it for a test drive above 80mph - actually I'm going to have their master tech do it (same guy that mounted/installed my wheels).
Old Jan 28, 2007 | 03:17 AM
Tomas's Avatar
Admin Emeritus
Scion is 'hubcentric' with a 54.06 (54.1) diameter hub.
Tom
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
