Mini wheels.
The AC Schnitzer wheels for the Mini Cooper won't fit without a spacer kit of some sort. They're 17×7.5 ET48 and will hit. I already tried a test fit. 15mm spacer kit ought to do. Centerbore is also off by 2mm. The Mini's is 56.1mm and the Scion's of course are running 54.1mm so rings will be needed as well. If you could find some old school wheels for the BMW E30 chassis 3-series, and ring those... that'd be sweet. They're 4×100 ET20 or so.
These wheels are from Hamann motorsports. 18*8" wheels 4x100 with a pretty nice lip.
http://www.fast-autos.net/hamann/mini5.html
I am buying these in a few months.
2 things to keep in mind. #1 • I believe the wheels are 18×8.0 ET43 so spacers will be needed. This will hit in the rear for sure. #2 Double check the seat on the wheels. The ACS wheels for the Mini are set up to use ball seat lug bolts so custom ball seat lug nuts would be needed on the Scion. Not too sure on the seating of the Hamann wheels so you may want to double check.
Hey Rbloedow, I know someone with a Cooper S that just upgraded to the AC Schnitzer wheels. If you're intereted I can see if he wants to sell his stocks (they are the ones in the image you posted).
The bolt pattern is perfect. You will need a 2mm hubcentric ring (Mini's centerbore is 56.1 and the Scion's is 54.1) and most likely a spacer setup as the Mini runs a really high offset and the Scion is more on the mid to low area.
[quote="Kendo"]... You will need a 2mm hubcentric ring (Mini's centerbore is 56.1 and the Scion's is 54.1).../quote]
They don't make a 2mm hubcentric adaptor ring - you need to bore out the stock wheel to take a 60x54.1 ring. The 2mm is too thin and will break.
I just had it done on a set of Minilites that I kept when I traded my MINI. It will cost you around $120-$160 plus the rings and any shipping.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
umnitza
Sep 1, 2015 08:06 PM
