nitrogen filed tires
So i roll up to costco, and i see a sign that says...
NITROGEN FILLED TIRES....BETTER HANDLING...BETTER GAS MILEAGE...ETC
now how can you even justify paying 40 to get your tires filled up with nitrogen? How are people on this earth sooooo stupid that they actually believe something of this nature will actually do something worthwhile. Is there any sort of proof/evidence that might suggest it is better than air? Please enlighten me.
John
John
I heard about this on motorweek on the speed channel and they said it really does work. "When you put nitrogen in your tires then your tire pressure remains constant."
Heres an article about it: http://www.waff.com/Global/story.asp...7&nav=17jVRjuL
Ok the real benefit from using the nitrogen is that the molecules are quite a bit bigger than regular oxygen molecules and in turn will not seep out of your tires over time. Where the oxygen molecules will seep out. Also the nitrogen will not expand or contract while being hot or cold, so your tire pressures remain the same all the time. I have had nitrogen in my car for almost a year now and have not dropped in pressure at all. It is definitely worth the 40 dollars to get them filled. The only way that you will need a refill is if your tire would get punctured from a nail or something.
Hope this helps
Hope this helps
Team Sushi
yes. . . the air that we breathe is mostly composed of nitrogen. . . pure nitrogen would be less sensitive to changes in temperature than the the oxgen, nitrogen, and other crappy gas mix that exists in our air. . . but is it worth $40. . . dunno bout that.
I asked my father-n-law about this. He has been a mechanic for over 30 years. He also works on Military jets now. anyway, check out this article on Nitrogen for jet plane tires.
http://www.physlink.com/Education/AskExperts/ae192.cfm
Dont remember where I found this! But, I put it in quotes.
[i]Nitrogen filling stations at tire dealers are becoming more common. This is a fairly big deal for the consumer. One of the biggest reasons for premature tire wear is improper inflation pressure. Assuming that a tire was inflated to the recommended pressure at the time of installation, it will overinflate from normal road friction as it becomes heated, or heated from a hot sun on the black sidewalls. When the temperature drops as it often does in the Northern latitudes, the tires will become under-inflated and start scrubbing. In the Fall, when you typically see wide temperature variations, keeping your tires inflated to the proper pressure is a time-consuming and difficult chore, and that's why most people don't even bother, especially on big rigs. With Nitrogen-filled tires, this problem is solved. Nitrogen is a totally inert gas and does not expand or contract with temperature. So if your tires were inflated to their proper inflation at installation, say 100 psi, then they will be 100 psi at 30 degrees and 100 psi at 115 degrees.
The added bonus with Nitrogen is there is no moisture
in your tires."
Look for a nitrogen filling station in your area. Nitrogen can extend tire life by 25 percent, improve fuel economy, eliminate rim corrosion, and tires will run cooler.
in your tires."
I can't remember the number, but our air is overwhelmingly mostly nitrogen (80% maybe?). so, if the smaller crap leaks out, then over time refilling your tires as they drop in pressure will eventually leave your tires with all nitrogen (as the limit of fill ups reaches infinity the presence of smaller molecules like oxygen goes to 0, simple calculus.).
X + (100-X)*80% = X where X starts at 80. So after one refill, you’re at 96% N2, After a second you’re already at 99.2% N2. So, I’d say $10 or $40 for a fill up of N2 is a waste.
Nitrogen N2 78.084%
Oxygen O2 20.947%
total 99.998%
Nitrogen N2 78.084%
Oxygen O2 20.947%
total 99.998%
George will chime in with the real formula shortly, since I can't remember math notation anymore.
(pseudo code below)
double ntwo, n = .78084;
double target = .999;
int count = 0;
while(n<target) {
n=n+((100.0-n)*ntwo);
count++;
out.println(Integer(count).toString());
(pseudo code below)
int count = 0;
while(n<target) {
count++;
I agree that using nitrogen keeps the tires free from moisture.
The inmediate benefit is that with the moisture out , there is less mass of gases in the tire (N2 mass + H2O mass) therefore reducing heat build up.
This means that a tire filled with regular air is more likely to overheat due to temperature and friction than one filled just with nitrogen that, by the way, will come dry off of the bottle due to the particularities of the bottling process (cryogenic process).
Regular air for tires is obtained from air compressors. Is a fact that the air we breathe contains moisture, or water, that if is not removed will make its way up to the tires. Also air compressors work with oil, so if no actions are taken oil will also make its way to the tire. Nobody knows the operation conditions of air compressors at gas stations or how are they maintained. To find good quality air is a lottery unless we know facts about a particular gas station compressor.
In a manufacturing environment, every time I install a piece of machinery that needs dry and clean air, I make myself sure to install an oil remover (coalescent filter) and an air dryer before the comsuption point.
Now, I have to clarify from an engineering standpoint that IS NOT TRUE that nitrogen will not change its volume with the temperature.
Nitrogen, as any other gas, behaves according the IDEAL GAS LAW, and IT DOES CHANGE its PRESSURE according to the TEMPERATURE and MASS existing in the container (tire). The equation that governs the pressure/volume/temperature changes is PV=nRT. It can be found in any thermodynamics book.
Probably what the people may perceive as no pressure change is that proportionally, for the same temperature differential, the pressure change for the air is greater than for nitrogen.
Just my 2 cents
QUESTION: I would like to know if there are any other Mechanical Engineers at ScionLife or this forum - thanks
Just my 2 cents
i work at costco in my area. i do not work in the tire center but i do about what goes on and what we offer out there. when my tC comes in i will be putting nitrogen in my tires from what i have heard from the manager out there. nothing but good things. yes it might be $40, but if u can get it from costco its about $10 cheaper than anywhere else. ill ask at work and see what i can find out
Also, the molecular size does not play any rol in how fast a tire losses air. It is a sealability issue. The tire mounter must be sure to apply sealing compound to the lip of the tire before it is inflated to prevent leaks.
Is pretty difficult to separate air components at ambient temparatures. There is no such a thing like that oxigen will escape before the nitrogen if there is a leak. It takes about -300˚F / -185˚C to separate the air components trough a cryogenic process. There are also non-cryogenics processes that require special materials to reach the same goal. For more information check the link.
http://www.uigi.com/compair.html
