Offset, what can I get away with?
Old Dec 24, 2008 | 02:35 PM
Improbcat's Avatar
Default Offset, what can I get away with?
I'm trying to figure out rims for my race tires for autocrossing next year. I want to widen my track as much as possible to improve stability.
The Box will be about 1" lowered on Swift Racing springs come spring, and I'll be running a 15x6.5 or 15x7 rim with 195/55 tires.
I'm wondering what offset is best. My primary concern is getting as wide a track without risking rubbing on hard cornering, Aesthetics of what looks good is irrelevant as these will be my racing-only wheels.
I'm asking because the last thing you want is a rubbing or torn tire when you're doing this or this.
Old Dec 24, 2008 | 02:52 PM
bluebox_02's Avatar
if ur gonna run 15x6.5-7 u should b able 2 run whatever off set u like, when u get into tha 15x8's is when offset becomes a big deal
Old Dec 24, 2008 | 09:16 PM
SR20DE_MAN's Avatar
I think you can get as low as a +30 mm offset & not rub at all. You could probably even get away with a +25 offset if you're doing a 6.5 to 8" wheel.
Old Dec 25, 2008 | 04:38 AM
swartzautoman's Avatar
6.5 to 7 wide rim shouldn't be an issue.
im on ajustable coilovers that ive got set up to be a little lower that the s-techs, ive got 16x8 +15 and no rubbin.
well..... my rear fenders are also rolled.
but your not going that low.
my front end is a little under 4" off the ground.
my front is lowerewde about 2.2-2.4, and the rear is 1.8-2.0
if your only going 1" and a 6.5 to 7 rim you should have no problem with any offset.
go with a 0 is you can find it
Old Dec 25, 2008 | 04:43 AM
dexter_5000's Avatar
+38 offset or lower i believe would be what you'd want. i'd go a 205 for section width on the tire put down a little more contact patch for hooking up.
Old Dec 25, 2008 | 10:57 AM
Boxer_Rebellion's Avatar
you could run et15 f/r and you'll be fine.
Old Dec 25, 2008 | 10:53 PM
DJ_SpaRky's Avatar
^ on an 8"
You should be fine running anything that you can find (that is a positive offset) on a 6.5/7 and not have issues. Most will be +35 or so.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
