THE RIDE W/ 17"s
Old Apr 28, 2005 | 01:04 AM
aedwards's Avatar
Default THE RIDE W/ 17"s
Does the ride get worse when you have larger rims?? For example, i am looking at 17's. Thx in advance.
Old Apr 28, 2005 | 01:12 AM
squareone's Avatar
Of course it does. Less rubber = less comfort.
Old Apr 28, 2005 | 01:18 AM
iNFEktEd's Avatar
perfectly said...
Old Apr 28, 2005 | 01:19 AM
aedwards's Avatar
Then why do so many ppl get 17's and all when the ride already is a little choppy??
Old Apr 28, 2005 | 01:20 AM
iNFEktEd's Avatar
for looks... i myself am running 19's and the ride isnt as bad as i thought.
Old Apr 28, 2005 | 04:04 AM
YELOSUB's Avatar
Wagonistas
I went with 17 x 7" with a 215/40/17 tire with a 2" Gold-Line drop. IMO, the ride quality is much improved. If you go with 17's, I say get the 40 series or even the 45 series.
Old May 5, 2005 | 11:02 PM
irv_usc's Avatar
the ride has improved ever since i switched to progressive springs. the linear springs + rate in the stocks were the cause of the choppy ride.
Old May 9, 2005 | 05:51 AM
sensez's Avatar
how do 17s fair to 15s in reference to mpg?
Old May 9, 2005 | 08:24 AM
xBino's Avatar
depends on the weight of the 17s. In most cases, they will be heavier, making for lower average mpg than 15s.
this drop in mpg will be most significant in city driving traffic or stop/go traffic
Old May 9, 2005 | 09:35 AM
ScionxR's Avatar
i got some used 17" off a guy and they had 205/40ZR17 tires on them. i want Pirelli P-Nero Zero M+S, but theyre not in a 205, just 215. whats teh difference? Also if the 17's were lighter would it be better MPG?
Old May 9, 2005 | 04:10 PM
M-Flo's Avatar
215 is wider by about 10mm. They will fit 17x7 in wheels.
And to answer your second question, no. You would still get less MPG since your tires are wider and stickier.
