Stock 15" wheel weight
Hi Guys,
Does anyone know how much the stock 15 inch steelies weigh. Also, how much would the average 17" aluminum/alloy wheel weigh?
Trying to figure out how much weight I can pull out.
Thanks
Thanks
17" wheels vary from 13lbs in upwards to high 20's
www.wheelspecs.com is a good resource that has wheel weights but you shouldn't group all 17's in one category...
keep in mind that forged wheels will be lighter/stronger/ and higher priced
vs
ebay 17's where it will be the opposite.
vs
Or 15" steelies are approx. 19 pounds each.
ALSO.. keep in mind, the bigger the size of tire/wheel you go to- the tires themselves get increasingly heavier(ie. 15" = 18lbs , 16" = 21 lbs .... etc, etc.). ALSO-also... keep in mind that the most crucial wheel weight(most important) is the outer-most part of the wheel (ie. the TIRE)!!!!!
Personally, IMHO.. a nice 15 or 16" wheel looks darn nice on a xB or xA. Going to a 17-18" wheel looks like way overkill , and makes the wheels look very disproportionate to the size of our vehicles. A tC looks good w/ 17"... and helps keep the weight down vs. going to a 18".
There are great deals on 16" wheels around.. from quality makers( 1 or 2 piece cast) , and a 16" tire is very-very similarly priced as 15" tires. I'd recommend either going w/ a superlight forged 15" wheel( SSR type-C @ $300 ea. = they only weight 8.5 lbs!!!) w/ a 195/55/ 15" tire on there. Or possibly going with a 16" wheel w/ like a 195/50/16" or 205/50/16"(less mpg this way.. but better grip).
Discount-tire direct is having an instant $100 savings on any 4 tires you want right now till Saturday... + free shipping !!!
welcome!
Also, keep in mind.. the stock tires on our xA's (185-60-15), when I had those things on .. I'd get blown all around the hwy/freeway @ 55-65 mph .... very frusterating/ unsafe if you ask me. Once I went to my wheel set up w/ 205-50-16" .... I'm good to go, stuck like glue even w/ heavey winds. Even going to a 195 wide tire should provide alot of positive feedback while driving... its the best upgrade you can do to your vehicle , hands down.
Yeah... probably a 195-50(or 55)-16" would be good. There isn't too much of a selection when you looking at that sizing. Where there are alot of choices, is when you looking @ 205-50-16"
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
darkshadowofxdeath
12-03-2014 06:59 PM
sithscripter
10-05-2003 06:54 PM
