What size tires for 16x8 +15?
Old Feb 11, 2008 | 01:57 AM
DIRTYMARTINIXB's Avatar
Default What size tires for 16x8 +15?
OK, I just ordered SportMax 501's
16x8 +15 offset that is a 3" lip per the Sportmax website.
I have the Tein STechs springs that have a 1.7" front drop and 1.5" rear drop.
I want a set of tires that I don't have to stretch.
What size should I get?
Also do i need spacers for these?
If anyone has size set up please post what sizes for tires and spacers you used if you had to?
P.S. I do not want them to stick out and look like a and old roller skate. Tongue
Thanks guys and gals!
Old Feb 11, 2008 | 02:28 AM
swartzautoman's Avatar
205/50/16 is your best bet. get the falcon 912, nice tire for a good price
http://www.edgeracing.com/tires/2055016/
im ordering the same set up in less then a week.
the 0 off set would make them stick out like theroller skates.
get a 15mm hub shimm for the rear and it will look nice, no rubbing issues at aLL
Old Feb 11, 2008 | 04:17 AM
Boxer_Rebellion's Avatar
I would get 205/45/16s for better clearance. You might still need some camber tho.
Old Feb 11, 2008 | 01:12 PM
50 is not any wider then 45
50 Will fill out the wheelwell by extra 5 mm more than stock. Acceptable for most cars.
the problem with the 45 is its .5" shorter then stock and
When speedometer reads 60mph actual speed will be 58.7mph 2.2% slower.
with the 50 When speedometer reads 60mph actual speed will be 60.9mph 1.5% faster.
its all up to realy, its hard to get a tire to be the same when you are dealing with this size. i all depends on what you want.
for me im going with the 50 because id rather be going .9 MPH faster than 2.3 MPH slower and +5mm is nothing to be worried about.
if you wanted to stay farther away from the fender (not that you should worry about the 205/50/16) you could use a 195/50/. this would come away from the fender only .2" over the 205/50 and When speedometer reads 60mph actual speed will be 59.9mph 0.2% slower then with stock.
Old Feb 11, 2008 | 08:11 PM
Leo_EdgeRacing's Avatar
I agree with 205/50R16.
Old Feb 11, 2008 | 09:03 PM
with the 16x8 +15 offset you will not need any camber, not with just the s-tech.
now if you used the 0 offset and used the echo struts, then you might have a few small issues.
Old Feb 11, 2008 | 09:11 PM
PakanaHerruus's Avatar
hmmm since this has been asked.. maybe you guys would know what tire to run with the Sportmax 962's with 17x7 wheels.. i plan on running the Falken FK-452's.. but dont really understand tire sizes.. i dont know how to find the right width..
Old Feb 11, 2008 | 09:25 PM
205/45R17 is the recommended size for the box, but no one really runs that size. It's a bit too narrow for one's liking. I would go 215/45R17 because it is the closest to stock and its wider than 205. If you have more questions, do not hesitate to ask.
Old Feb 12, 2008 | 01:19 AM
swartzautoman
...15mm shim spacer will make the rear track match the front track? I wont need to roll the rear fenders right? I really do like 205/50/16 tire size...I had them before and l love the performance and ride for this size tire.
Sorry for all the questions, tires and wheels are not my strong point!
Old Feb 12, 2008 | 01:21 PM
im not sure about the 15mm.
im about to find out, ive got the 15mm and im ordering this same setup in a few day, so ill be able to lrt you know.
im quessing that it wont be a problem. if it is im just going to come down to the 10mm or IDK i might just roll the fender anyway.
give me time to get the wheels in and ill let you know for sure.
Old Feb 12, 2008 | 02:34 PM
Trust me, you'll rub. I rub right now (slightly) with 205/50/16 with 35 offset and 15mm spacers. AND my fenders are rolled a bit.
I'm on my 8th set of wheels and about to get another set (SportMaxes coincidentally...)
Less diameter will lessen the chances of rubbing. That's why people run undersize 195/45/15's on SportMax 002's.
Old Feb 12, 2008 | 04:53 PM
so you have 16x7 + 35 and a 15mm spacer with rolled fenders and you still rub?
is it just in the back that you rub? how bad?
ive got the same spring and strut setup you do with 15x7 + 38 and i never rub
ill look into the 195/50/16
Old Feb 12, 2008 | 06:59 PM
I rub only over big dips, just slightly. But I know with 20 more negative offset I'd be shredding tires.
Old Feb 12, 2008 | 07:00 PM
Oh yeah, only in the back.
Old Feb 12, 2008 | 09:56 PM
thats strange.
ive talked to so meny people that are running 8" rims with 15 offset and 0 offset, and ive only herd the 0 offset guys talk about rubbing problems
Old Feb 13, 2008 | 12:29 PM
STLBOX's Avatar
I have 205/50/16 on Sportmax 501 16x8 and they WILL rub. I am lowered about 1.5"
The tire does fill the wheel well nicely though.
Old Feb 13, 2008 | 12:46 PM
stlbox: whats your offset?
your profile said you have a staggered setup?
so what do you think then, should we go with a 195 or should we get rid of the rear spacer, ive got a friend thats been buging the crap out of me to swop spacers he has a 10mm.
Old Feb 13, 2008 | 12:50 PM
STLBOX's Avatar
Here is the info on my setup. it should cover everything.
https://www.scionlife.com/forums/vie...769&highlight=
later
Old Feb 13, 2008 | 01:15 PM
ok...
so ill just get the 195/50/16 and come down to a 10mm in the rear or get rid of the spacer all together.
Old Feb 14, 2008 | 02:09 AM
STLBOX's Avatar
205/45/16 would be a good choice too. I personally feel you need a 24" tire to fill in these wheel wells no matter how low you are dropped.
later
