What size tires should i get for 16x7? and spacers
Old Jan 4, 2007 | 11:15 PM
Robot_Box's Avatar
Default What size tires should i get for 16x7? and spacers
i just placed an order for some 16x7 with +30 i was just wondering what size tires i should be getting. i also i plan i getting a 20mm spacer for the rear and about a 10 mm spacer in the front.
Old Jan 5, 2007 | 09:51 AM
RedneckwithanxB's Avatar
IIrc it was a 205-55 or a 195-55...
I know my friend Jorge has 205-55... nice and wide and meaty...
about your spacer question... im not all to sure, i had a 10 on my rear with my 15s and it was just fine... but if your lookin for that flush ook you might wanna do what ya said...
Old Jan 5, 2007 | 12:50 PM
DJ_SpaRky's Avatar
The offset would be right for 8" wide, you don't need as low, try 5/10mm instead, or OTG Hub Spacers & 5mm all around.
On to Tires, 205/55 should be fine, but if you want a streched look, got for 195/50s. I'm thinking about getting 16x8 (501s) and running 195/50/16.
Old Jan 5, 2007 | 03:47 PM
dexter_5000's Avatar
i just put 16x7 wheels on my car with 205/50/16 tires.
Old Jan 5, 2007 | 03:52 PM
Dewmerz's Avatar
on a 16x7 205/55/16 is too big. That is a inch over stock rolling diameter. I had 205/50/16's on my 16x7's until last week and even that was over stock but between the US/JDM OEM tire sizes.
Old Jan 5, 2007 | 03:53 PM
205/50/16 is the happy medium i think
Old Jan 5, 2007 | 06:07 PM
Robot_Box's Avatar
would 16x8 fit the car? with out spacers? and with no rubbing?
Old Jan 5, 2007 | 06:10 PM
that can all depend on your drop if you have one and offset of the wheels.
Old Jan 5, 2007 | 06:11 PM
cherryBox's Avatar
^^^ 16x8? totally, if you get the right tire. also, if you haven't bought them yet, check out the sportmax 501 +15 - you won't need spacers!
Old Jan 5, 2007 | 06:35 PM
Robot_Box's Avatar
i read some where that i should get a 205/40/16
Old Jan 5, 2007 | 07:18 PM
Subcompact Culture's Avatar
Running a 205/50/16 is the correct size tire if you want to keep your speedometer correct. This is what I run.
I currently run 35 offset with a 15mm spacer in the rear (for a total of +20 in the rear) and I do not rub with my 16x7s. I swear -- a millimeter more, and I'd probably rub when I have people in the back seat.
Old Jan 5, 2007 | 07:24 PM
ElChupacabra's Avatar
16x7 Rota rims...
205/45 on the front 225/40 on the rear. Its a sweet setup and looks great. Check my profile for the pics.
Old Jan 5, 2007 | 10:34 PM
Robot_Box's Avatar
hey ElChupacabra what offset do you have?
Old Jan 6, 2007 | 06:39 PM
I'm pretty sure they are 40 offset. I bought them from a friend so Im not 100% on that. They definately fit and I'll be running 25mm spacers in the rear with camber shims from OTG for a flush mount and some 10mm spacers in the front...
Old Jan 6, 2007 | 09:46 PM
xA_Factor's Avatar
As others have mentioned, a 205/50 is the most ideal.
Old Jan 7, 2007 | 05:34 PM
Zillon's Avatar
I run a 205/50 on mine...
Old Jan 10, 2007 | 11:02 PM
Xbguy1's Avatar
thats the same set up i will be runing with my dr-16s
Old Jan 11, 2007 | 04:17 AM
its really a nice balance imo.
Old Jan 11, 2007 | 12:22 PM
RedFox180's Avatar
Try Jon at 1TDA.com He's very knowledgable about these kinds of things.
rain7905643
Mar 14, 2015 12:48 AM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
mdhyre
Dec 7, 2014 12:52 AM
SkateVandal
Nov 27, 2014 02:34 AM
GreatWhitexA
11
Dec 23, 2003 05:25 AM
