will wider tires void my warranty?
Old Oct 9, 2006 | 08:22 PM
benwolfe's Avatar
Default will wider tires void my warranty?
My Wifes xa is in serious need of new tires. I want to go wider but keep the same ride height. Will wider tires void my warranty? I was thinking of going with 205
Old Oct 9, 2006 | 10:05 PM
xA_Factor's Avatar
No.
Old Oct 9, 2006 | 10:13 PM
Tomas's Avatar
Admin Emeritus
The ONLY time any PART of a warranty is affected is if what you have done directly caused a failure to happen.
That's the quick answer. There is a lot more. Search.
Old Oct 10, 2006 | 12:21 AM
ChampionJeep's Avatar
205's are a touch lower than the stock tires. But, you won't have any problems with warranty work.
Old Oct 10, 2006 | 12:45 AM
xA_Factor's Avatar
It depends on the size he goes with. A 205/55 is a little shorter, but a 205/60 is a bit taller. Both are well within the recommeded +/- 3% difference verses the stock rolling diameter. Personally, if I were going with a 205, I would go with the 205/60.
Old Oct 10, 2006 | 01:10 AM
Tomas's Avatar
Admin Emeritus
Yes, if it is a choice between 3% shorter and 3% taller, I'd definately go with the taller unless they for some reason just plain won't fit.
Here's some detail on warranty stuff I didn't have time to look up before:
https://www.scionlife.com/forums/viewtopic.php?t=55338
Tomas
Old Oct 10, 2006 | 01:20 AM
boogi_man's Avatar
in that size range what's the word on the yoko avid trz's? anything better. regardless of cost?
Old Oct 10, 2006 | 01:33 AM
Tomas's Avatar
Admin Emeritus
The Yoko AVIDS are in the top three for street tires IMHO.
Tomas
Old Oct 10, 2006 | 01:51 AM
boogi_man's Avatar
any better? not wanting to start anything just want to know
Old Oct 10, 2006 | 02:01 AM
xA_Factor's Avatar
Here ---> http://www.tirerack.com/index.jsp
Old Oct 10, 2006 | 02:05 AM
boogi_man's Avatar
i've been looking there and the numbers are all fine and good i was hoping for some expereiance. i have a set of sportmax 003's in the 15x6.5 size and am looking to upgrade the rubber along with the wheels
Old Oct 10, 2006 | 02:24 AM
Tomas's Avatar
Admin Emeritus
Quite seriously, there is no one "BEST" tire.
ALL tires are compromise designs, and it depends on what is most important to you at this particular moment which of your many choices might be best.
On a rainy day tire "A" might suck, even though on a dry day it beats all the others.
Tire "B" may have ten times the tread wear of the others, but might make most roads feel like they've been greased.
Tire "C" might be fantastic is snow, but self destruct driving to Barstow in the summer.
There is NO best tire, only tires that are better than others at specific jobs. It depends on what is important to YOU that the tires do.
Even then, that can change by the hour.
Look at races - the slightest bit of rain and all the cars come in to change tires. Their hyper-expensive, purpose designed, "best tire for the job" is suddenly no longer "best."
Here's a typical rating list (lifted from Tirerack) showing the stock tires on my xB and the tires I chose to replace them. (Details in my profile.)
Note that while the tires I chose are at the top of the list, they are NOT best in all things. (Also notice that the OEM tires are NOT best in ANY factor...)
Decide what is important to YOU and make a choice.
Tomas
powerT
11
Apr 16, 2015 02:31 AM
ScionDP
Mar 13, 2015 10:16 PM
kidkamel
14
Jan 18, 2008 11:39 PM
morph1119
Dec 24, 2003 07:38 PM
stankubrick
32
Nov 24, 2003 03:43 AM
