**HELP** HID Installation ??????
Old Feb 7, 2012 | 05:41 PM
Wooodis's Avatar
Default **HELP** HID Installation ??????
Hello all! This is my very first post on here. I have a 2005 Scion XB 1st gen. And I'm trying to install an HID Lighting system on it but running into some problems. Well actually 1 problem with the wires going into the ballast and connecting to the cars original light bulb plug. The connection adapter has there extra red and black wires sticking out. I have no idea what to do with them??
Old Feb 7, 2012 | 06:02 PM
AnotherDude's Avatar
Pics are your friend.... Brand?
Old Feb 7, 2012 | 06:10 PM
my06tc's Avatar
post some pics of what you have..do you have a relay harness included or no
Old Feb 7, 2012 | 06:32 PM
Wooodis's Avatar
Ok, gonna go home in a bit to post some pics up.
Old Feb 7, 2012 | 11:09 PM
Wooodis's Avatar
[IMG][/IMG]
Old Feb 7, 2012 | 11:10 PM
Wooodis's Avatar
These are the connectors with the extra red & Black wires.
Old Feb 7, 2012 | 11:11 PM
Wooodis's Avatar
This is an extra set of bulbs and ballasts from Xentec I believe. I tested out the ballasts and they both work.
Old Feb 8, 2012 | 12:11 AM
jaylouie's Avatar
the extra red and black wires is wired for the high beams that you will no longer have with that hid kit. So just tape the wires off and don't use them
Old Feb 8, 2012 | 12:37 AM
my06tc's Avatar
yup that extra wire is for the high beams which is no longer used....
Old Feb 8, 2012 | 12:51 AM
Wooodis's Avatar
Really?, when I installed the this system the first time the lights did not even turn on...??
Old Feb 8, 2012 | 12:54 AM
Wooodis's Avatar
Does the ballasts have to be from the same brand as the Bulbs?? Because I know that its both different.
Old Feb 8, 2012 | 04:36 AM
jaylouie's Avatar
make sure you have the correct polarity on everything. Check the wire that connects from your oem harness into the ballast. you can easily plug it in with the polarity flipped on the ballast side.
Old Feb 11, 2012 | 02:54 AM
Wooodis's Avatar
I am stumped I have no idea why these lights aren't working!!!! I never had any type of problem installing Hid's into any car until this Scion! What am I doing Wrong????????????????????????????????????
Old Feb 11, 2012 | 03:54 PM
Reactor's Avatar
Looks like you have the polarity reversed. The Black/White wire is a ground signal but from the pic you posted it looks like it connects to the Red wire to the ballast. The HID kits are usually not plug and play when it comes to Toyotas.
Old Feb 11, 2012 | 08:54 PM
Wooodis's Avatar
Ok, im gonna try switching out the connectors to see if it works. Thanks.
Old Feb 14, 2012 | 05:55 AM
jaylouie's Avatar
try turning on the high beams also. the harness might have been made wrong. But i'm not sure if it is made wrong
Old Feb 14, 2012 | 05:59 AM
jaylouie's Avatar
actually looking at it, the company that made the h4 plug adapter that plugs into the stock h4 plug made it wrong. the High beam wires and the low beam wires are switched. so try to turn the high beams on and they should light up.
Old Feb 14, 2012 | 06:30 PM
burstaneurysm's Avatar
If you have a small, flathead screwdriver, you can swap the pins on that male H4 connector. That should do the trick.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
clickclickw00t
Feb 18, 2015 08:57 PM
tc_Jake
Dec 31, 2014 01:45 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
